Forum: FPGA, VHDL & Verilog Regarding FFT & IFFT in VHDL
von varun m. (Company: DEI) (varun_agr)
Sir
I am trying to use FFT 5.0 core in xilinx10.1 as follows for 50 hz
SinWAVE(THROUGH ADC)for noise removal
1. 64 Transform size
2. Radix-2 burst mode
3.I/p data width 8 bit
4.Scaled
5. Natural order(without cylix prefix)
I want to know what is the value of scale_sch for FFT and IFFT for
getting O/P width same as I/P width i.e 8 bit in my problem. As I want
to use same IP core for FFT and IFFT.Further I want to use inverse FFT
for the O/P fft i.e XK_REAL AND XK_IMA.and display the same sine wave
via DAC. So what is the procedure after FFT.Should I remove all real and
imaginary except fundamental frequency i.e calculated by xk_index.and
give this to FFT core(for inverse FFT) or anything else, kindly suggest
me
bye
Varun
von B.B. (Guest)
This doesn't make sense. There is no need to make an FFT over all freqs
if you just want to keep one of them. Do an IQ-Modulation-Demodulation
with a sharp small band filter in between.
