Forum: µC & Digital Electronics AVR RF12B problem
von Davide T. (Company: Polytechnic of Turin) (dadomgilmour) Flattr this
Hello to everybody,
I'm new here. I think that it is a good forum and I hope that you can
help me.
I have two devices composed as follow:
ATmega328P <--SPI--> RF12B
I created my own library but I have a big problem. The two devices
(configurated as transmitter and receiver respectively) communicate well
but the receiver miss a lot of characters. The receiver cannot receive
up to 3 bytes (excluding the preamble and the synch bytes). It is very
strange and makes me mad! I tryed a lot of methods to avoid this
problem, but with no results. I am sure that the problem must be the
underflow of tx's buffer or the early stop in receiving.
other info:
- I use polling RX (Read the Status, then FFIT control and finally do RX
byte command for reading the FIFO)
- During TX, SDO signal confirmed me the receiving of all the bytes
example:
TX: AA AA D2 0A 0B 0C 0D 0E AA
RX: 0A 0B 0C
Any suggestions?
Thank you in advance!
Davide
von Thomas B. (nichtessbar)
overrun of receive buffer... i'm not quite sure with spi, but most avr
usarts behave this way if receive buffer isn't read fast enough, in my
opinion 3 bytes is a characteristic value for AVR receive buffer
overrun...
Thank you for your answer Thomas!
I think that this problem is not related to SPI's buffer overrun,
because every time I get the data I wait the SPIF flag and then I get
the data from the buffer. It should prevent from the buffer overrun.
Isn't it? I think that the problem is related to the speed of getting
the data from RX's FIFO.
Now I am using another method: When the reading of RF12B's status
returns me FFIT flag I force the reading of 8 byte.
With this bad bad method I can see this:
TX(payload): 0x0A,  0x0B,  0x0C,  0x0D,  0x0E,  0x0F,  0x10, 0x11
FROM TERMINAL (RX)
Start!
Inizializzazione terminata! (=end of init)
frame RX:
 0x0A,  0x0B,  0x0C,  0x0D,  0x0E,  0x0F,  0x11,  0x0F,
frame RX:
 0xFF,  0xFF,  0x0A,  0x0B,  0x0C,  0x0D,  0x0E,  0x0F,
frame RX:
 0x10,  0x07,  0x0A,  0x0B,  0x0C,  0x0D,  0x0E,  0x0F,
frame RX:
 0x11,  0x07,  0x0A,  0x0B,  0x0C,  0x0D,  0x0E,  0x0F,
frame RX:
 0x11,  0xC7,  0x0A,  0x0B,  0x0C,  0x0D,  0x0E,  0x0F,
there are a lot of mistakes but I have received more than only 3 correct
bytes now :)
NEWS:
TX(payload):
0x10,  0x0A,  0x0B,  0x0C,  0x0D,  0x0E,  0x0F,  0x10,  0x11,  0x12,
0x13,  0x14,  0x15,  0x16,  0x17,  0x18,  0x19
frame RX:
0x13,  0x14,  0x15,  0x16,  0x17,  0x18,  0x06,
frame RX:
frame RX:
0x13,  0x14,  0x15,  0x16,  0x17,  0x19,  0xC6,
frame RX:
0x13,  0x14,  0x15,  0x16,  0x17,  0x19,  0xCF,
frame RX:
0x13,  0x14,  0x15,  0x16,  0x17,  0x18,  0x07,
frame RX:
0x13,  0x14,  0x15,  0x16,  0x17,  0x18,  0x3D,
The problem is related to the last two bytes!
von rfm (Guest)
you have to send 2 dummy bytes at the end of your payload.
LAST NEWS:
my code works good! The problem was that I called the TX stop command
too early!!! :)
Bye :)
No, the dummies are not mandatory.
von rfm (Guest)
If your tx routine is programmed according to the datasheet, then just
one dummy is enough. Obviously it wasn't done so, and the last bits got
stuck in the tx buffer. Then the second dummy byte is next best
solution.
> solution.
What you have said is true! With the 2nd dummy byte all works fine!
Thank you! I have resolved the problem with a delay, but your solution
is the best if we think about a wireless sensor network application.
Thank you :)
von rfm (Guest)
Well, I had the same issues once. Also, the delay may look as a solution
at first but could cause a unwanted RGIT-IRQ if too long, because the
RFM wants to transmit another byte and so get the tx buffer filled up
again.
Cheers.
