Forum: FPGA, VHDL & Verilog Counter problem - input not loading
von David O. (mucker2b)
Hi - first post here,
I am trying to describe a counter which accepts an address and
increments by 1 each cycle. The problem is that the counter always
starts at 0 even when reset is '0'. I have attached the code below. Can
anybody see where I am going wrong? I thought that by assigning the
value 'a' to 'temp_address' in the process that it would work as
expected.
Any feedback welcome - thanks.
entity c1_new_address is
generic (n: integer := 14);
port (a: in std_logic_vector((n-1) downto 0);
    clk, reset: in std_logic;
    w: out std_logic_vector((n-1) downto 0));
end c1_new_address;
architecture Behavioral of c1_new_address is
signal temp_address: std_logic_vector((n-1) downto 0);
begin
  process(clk, reset)
  begin
    if reset = '1' then
    temp_address <= (others => '0');
    elsif rising_edge(clk) then
    temp_address <= a;
    temp_address <= conv_std_logic_vector((conv_integer(temp_address) +
1), 14);
    end if;
  w <= temp_address;
  end process;
end Behavioral;
von PittyJ (Guest)
There are two 'assignments' to temp_address:
 temp_address <= a;
1), 14);
Which one should get calculated. As far as I know, the 'compiler' takes
the last one and ignores all previous. Meaning the you will always get
1), 14);
and
 temp_address <= a;
is discarded.
I thought that as a process runs statements sequentially that both
assignments should get run in the order that they are in => on the
rising edge, temp is assigned the ip value and it is incremented on the
next statement.
I also tried assigning the value 'a' to temp_address outside the process
so that the same value doesn't get assigned to temp_address during each
run of the process with the ip address still not being assigned to
temp_address.
von mifi (Guest)
Hello David,
have you try this way:
temp_address <= conv_std_logic_vector((conv_integer(a) + 1), 14);
In this case there is only one statement.
Regards,
mifi
The assignments do not run, and they are not executed. You are thinking
in sequential software (like Basic or C). In real hardware all of your
statements are executed at the exactly same time (at the moment the
clock signal rises).
Having fixed that, you must have a look for the behaviour of signals in
a VHDL process: they don't change their values until the end of the
process. And then the last assignment "wins" and the signal gets its new
value.
Here X never ever will have another value than 7, because thats the
last assignment to this signal:
  process (A) begin
     X <= 1;
     X <= A+3;
     X <= 7;
  end process;
Here X never will increment, but just store the value of A:
  process (clk) begin
       X <= 7;
       X <= X+1;
       X <= A;
     end if;
  end process;
And here X will simply count up:
  process (clk) begin
       X <= 7;
       X <= X+1;
     end if;
  end process;
@ mifi - I used your method and it worked a treat.
@ Lothar - That was a simple and effective way of explaining the
assignment operation in a process.
Thank you gentlemen.
