Forum: FPGA, VHDL & Verilog Use of function and packages in testbench
von Raghavendra B. (raghavendra_b98)
I written VHDL function as package,how to use that function in testbench
code.
function to_max(a, b : integer) return integer is
  variable output :integer;
  begin
if (a > b)then
 output := a;
  return output ;
  else
output := b;
  return output;
  end if;
Thanks in advance
Regards
Raghvendra
von Duke Scarring (Guest)
Declare it:
library my_library;
use my_library.my_package.to_max;
Duke
Thanks for reply..i done that declaration part..my problem is how to
give input to a and b .
von berndl (Guest)
<glasshouse on>
... and you expect a usefull info or solution with the input that you
gave...?
<glasshouse off>
Thanks for your reply.I need soluation for inputs along with useful
information.
