Forum: FPGA, VHDL & Verilog VHDL "Pong" Game - Problem
von Gerard O. (ece101)
I'm learning VHDL and as I've got some time off I decided to write a
pong game!
I've run into a problem, In its current state, I am displaying the
"paddle" on the screen, however, when I try to move the paddle (see line
90) I get this error:
ERROR:Place:1018 - A clock IOB / clock component pair have been found
that are not placed at an optimal clock IOB /
   clock site pair. The clock component <leftled_OBUF_BUFG> is placed at
site <BUFGMUX_X2Y10>. The IO component
   <left_button> is placed at site <IPAD73>.  This will not allow the
use of the fast path between the IO and the Clock
   buffer. If this sub optimal condition is acceptable for this design,
you may use the CLOCK_DEDICATED_ROUTE constraint
   in the .ucf file to demote this message to a WARNING and allow your
design to continue. However, the use of this
   override is highly discouraged as it may lead to very poor timing
results. It is recommended that this error
   condition be corrected in the design. A list of all the COMP.PINs
used in this clock placement rule is listed below.
   These examples can be used directly in the .ucf file to override this
clock rule.
   < NET "left_button" CLOCK_DEDICATED_ROUTE = FALSE; >
I'm not sure how to interpret this error. I've attached the .vhd. With
line 90: "paddle_loc <= paddle_loc + 1;" commented out, there are no
apparent errors so far.
Also if someone could offer any tips on how I could improve the code to
follow good programming practices I would appreciate it.
>   -- Clock divide by 1/2
This way is a absolutely No-Go on FPGAs.
As a beginner you have exctly 1 clock on the whole design. And all other
("slower") actions are done by clock-enables. This one-and-only-clock
In your design design are much too much clocks. This is what the
synthesis is telling you (its a little more difficult but thats the
direction)...
This here is called a combinational loop (aka combinatorial loop):
>     if left_button = '1'  then --and paddle_loc > 200 then
What will paddle_loc do, when left button is '1'? Becsue theres no clock
involved, it will count up at maximum speed (and thats something in the
500MHz range)!
Ahh yes silly mistake!
As paddle_loc is declared as having a range from 0 to SCREEN_WIDTH -
PADDLE_WIDTH (roughly 540), I had assumed that the paddle would move so
fast I wouldn't be able to see it. I was just hoping to get the paddle
to move any way at all before I added a clock divider for its speed.
I've spent the past few hours greatly improving the design and I've now
got the paddle moving and ball bouncing around the screen!
I'll repost the code when I'm done to see if anyone see's anything which
could be improved :)
Thanks for the help
