Forum: FPGA, VHDL & Verilog help for Signal_quiet attribute
von sreeram s. (sresam89)
i used a code
x:=ORFLAG'QUIET(400 ns)
xilinx shows an error
"The predefined attribute QUIET is unsupported"
can anyone help.am i not using any special pacakages for this?
Read the "XST Users Guide".
You will find out, that the simulator can simulate much more than the
synthesizer can transfer to hardware. And you will also see: most of the
VHDL attributes are not synthesizeable.
thanks lothar.
sir it was your piece of code suggestion i tried for the stuck at fault
topic
http://embdev.net/topic/235605
can you please suggest any other alternative..
Yes, but there you did write:
>>>  the code is for simulation only
And in simulation this will work.
But not (and never) for synthesis on real hardware!
>>> can anyone please give me a piece of vhdl code for stuck at faults
>>> stuck-at-0 and stuck-at-1 for any sequential and/or combination
>>> circuits, just need it to start from the scratch.
Pls clarify what you want to do with this code? Waht do you need it
for?
> for?
sorry sir,
i noticed that u said it was only for simulation.
i need the code to to compiled using xilinx and see the simulation using
modelsim .
> modelsim .
Thats no answer to my question!
I just wanted to knwo: WHAT do you want to do? WHAT is your primary
task? WHERE does the signal come from? WHERE does the result go to?
In a real synchronous hardware design every time is realized by a
counter.
So if you want to check a signal for a stuck-at-1 for a certain time (in
your case obviously 400ns) and you have a clock (lets say 50MHz =20ns),
you can do it that way:
   signal cnthigh : integer := 0;        -- count the duration of the high phase
   signal stuckatone : std_logic := '0'; -- flag the stuck failure
   process begin
      wait until rising_edge(clk50mhz);
      if (cnthigh > 400/20) then -- end of time reached?
         stuckatone<='1';        -- we have a stucked signal
      end if;
      if (input='1') then        -- if the input is 1
         cnthigh <= cnthigh+1;   -- count up
      else                       -- if the input is 0
         cnthigh <= 0;           -- reset the counter
      end if;
   end process;
thanks miller.
>> modelsim .
my primary task will be to find the faults at basic gates. for the gates
i will use separate process or testbench for each one of them.
the signals for the gates comes from a Test pattern generator. no user
given inputs are necessary if not considering the clock that has to be
provided in the modelsim, no FPGA implementation is to be done.the
output of gates are to used just for fault recognition, and are of no
use further.
this is my task to be done
von Lattice User (Guest)
This begs the question:
Why do you need then to compile with the Xilinx Synthesiser?
In REAL HARDWARE or only for with a SIMULATION?
I didn't figure out this up to now...   :-/
= hardware?
> no user
= simulation
= simulation or ASIC
> the output of gates
= hardware?
> are to used just for fault recognition, and are of no use further.
i personally use xilinx to compose n compile the codes in vhdl.
any other suggestions?
sir i dont implement these codes in FPGA kits.I compile them under
xilinx and just simulate them in modelsim.
> = hardware?
no the TPG is also software written
>> no user given inputs are necessary if not considering the clock that has to be
> = simulation
yes am given only clock cycles for Test pattern generation that too in
simulation in modelsim.
simulation only
>> the output of gates
> = hardware?
not hardware just to see the simulated output in modelsim(output need to
be something which tell whether fault is present or not, could probably
be a report statement as u had given in the first post.)
yes am not going to use the output of the gates any further.
thanks for your precious time millar.
awaiting your reply
What you want to do can be done with the FPGA design flow, but you need
clearly understand what the difference between testbench and DUT (device
undet test) is. Testing on stuck signals, testpattern generator etc
belongs in the testbench. If done correctly the synthesiser will never
see it (in your case you don't even need to compile the synthesiser).
I think you are better served with a stand alone simulator. For example
Modelsim (i have no idea if the Xilinx version can be used standalone),
Aldec HDL or even GHDL.
> I compile them under xilinx
Why?
All of the work only must be simulated, and thats the only thing that
makes sense. FORGET the synthesis with XST. Why (at all) do you setup
the project in ISE? Do your work COMPLETELY in ModelSim. And never ever
check the design with a synthesizer...
Then the asttribute 'QUIET will work fine, and also the other ones....
> Why?
will ask you if any more query after i try them all in modelsim.
thanks for your precious support.
