Forum: FPGA, VHDL & Verilog loading hex data into RAM
von pakhi n. (manideepa) Flattr this
Hi all,
I want to read data from a file in vhdl.In verilog readmemh is used, but
please help me how to do that in vhdl.
von PittyJ (Guest)
Look into the book "The designers guide to VHDL" from Peter Ashenden.
The complete chapter 16 describes the file IO.
Search on Google for "hread vhdl".
Also try this with babelfish or google translator:
Beitrag "Problem Textio"
And, after all is said by PittyJ, there is one thing to remark:
@ Manideepa Mukherjee
why do you NEVER give a backlink to previous thrads with your own
similar questions? Why do you open a new thread Same as already
mentioned in the thread http://embdev.net/topic/240778#2447717
I tried loading data using the attached file it is simulator is giving
the following warning:
Simulation object /RLD/RAM was not traceable in the design for the
following reason:
The number of elements in the requested object is 200008, which exceeds
the maximum traceable size of 65536 elements.  The maximum can be
changed with the "isim set maxtraceablesize" Tcl command.
Simulator is doing circuit initialization process.
Finished circuit initialization process.
please help
von srinivasa c. (srinivasa_c)
dear sir,
we are working on data compression and we have to implement it using
serial and parallel methods, please help us for the following problem v
r facing while implementing-
1.how to clear" numeric_bit denoted by prefix ieee must exist in must
exist in the library" in altera max plus ii????
2. how to write LOOK UP TABLE program for huffman decoder??
3. is there any way to implement look up table in GRAPHIC EDITIOR MODE
in altera???
4. should we send huffman tree for decoding along with look up table for
decoding???
kindly, reply us soon.........
thank you.
