Forum: FPGA, VHDL & Verilog Multiplier using Vhdl
von Antros48 .. (antros48)
Hi all. I am trying to make a vhdl program about a 4bit X 3 bit
multiplier. I have made almost all of it but i get some strange results
when i simulate it.
von jeans (Guest)
aha
von nightowl (Guest)
secret code?
nightowl wrote:
> secret code?
Sercet simulation results?
> a 4bit X 3 bit multiplier.
Something like this?
   signal y : unsigned (6 downto 0);
   signal a : unsigned (3 downto 0);
   signal b : unsigned (2 downto 0);
   y <= a*b;
No the code is not secret :) It is attached to this reply.
Thank you for the reply
And the testbench?
What results do you get?
> architecture behaviour2 of multiplier4X3 is ...
Your description ist AVSOLUTY NOT a behavioural description. Ist a
completly STRUCTURAL description. So why is the name of your architectur
"behaviour2"?
BTW:
Why does everybody around the world write a half adder and a full adder
and a multiplier (and even a AND gate...) on their own?
Why not just using the VHDL operators + AND *?
About the name that is correct my mistake, i should change it. Now about
the half adder etc i wanted to do it like this so i can fresh my memory
about vhdl.
About the code i tried to changed it a little and i added a new signal
ztemp at the end of the code. The four lines named stage0-3 are replaced
with
stage0: fulladder4 port map (x(3 downto 0)=>k(3 downto 0), y(3 downto 0)=> l(3 downto 0),ztemp(3 downto 0)=>(z(3 downto 1)=>n(3 downto 1), z(0)=>P(1), Cout=>Cout1);
Still i get errors and i can't get it simulated like before, at all.
But here are the results of the simulation before, attached
Thank u!
Could you pls attach screenshots as *.gif grphics?
> Still i get errors
What sort of ones?
I only have it on bmp type. Can you open it?
It keeps saying "Error (10348): VHDL type mismatch error at
multiplier4X3.vhd(57): type of formal parameter "ztemp" does not match
port type of value"
Yes. And you are right: it looks like complete nonsense...
Does your full adder work properly?
Whats the theory behind your multiplier?
Do you have a schematic (with your signal names in it)?
