Forum: µC & Digital Electronics LCD EA W161B-ENLW wiring!
von Eva (Guest)
Hello.
I am a little bit confused. How to wire a LCD EA W161B-ENLW. Although I
have a manual, it is in german, and Im not to good understanding. Please
someome translate, how I need to wire VEE and pin15, pin16.
Google translate did not help me.
Does pin15 has to be plus 3 and pin16 minus 3 volts?
Thank you for your time!
Here is manual in german:
https://www1.elfa.se/data1/wwwroot/assets/datasheets/07540866.pdf
von Eva (Guest)
Forgot to mention: This particular information is located on page 2.
Thanks!
von knibbel (Guest)
Pin 15 and Pin 16 are being used for the LED-Backlight:
Pin 15 is the positive terminal.
Pin 16 is the negative terminal.
Both pins must be connected to a voltage source TOGETHER with a
resistor, to limit the current for the Backlight. The current should not
exceed 30mA, but you should try 15mA to 20mA first. The forward-voltage
for the LED-Backlight is somewhere between 3,0V and 3,6V.
Pin 3 (VEE) is used for the contrast(translation?) of the display and
should be connected to a slider of a 10k-potentiometer. The ends of this
potentiometer are to be connected to Ground (VSS) and 5V-Supply (VDD).
Hope this helps ...
Cheers,
Thomas
von Eva (Guest)
Thank You very much for the translation. It helped  a lot!
Cheers
E
