Forum: Analog Circuits Precision Measurement of Low Currents
von Analog (Guest)
Hi all
For Semiconductor process testing I need to mesure the gate leackage
current. There are many comercial products for this purpose available
(like Keithley xxxx, wich offer Mesurement sources with up to 10fA
precision). However this equipment is to expensive for us.
Im therefore looking for an alternative, with a precision opamp. I don't
need 10fA precision, but better than 1pA (voltage a bit less critical
but should also be very precise) would be good. A high range would also
be desireable so that I culd supply up to 12V 10mA. The Integration time
doesnt matter much but should not exeed a few sec.
Any sugesstions?
von uii (Guest)
Do a parametric search on low input current opamps. Some examples :
LPC661, LMC662, LMC6001A, ...
von W.S. (Guest)
You should look for a amplifier intended for pH measurements. I think,
NS has one: the E+ is well separated from all other pins and together
with a guard track connected to E- this amplifier yelds a input
impedance of (as far as I remember..) some 1E12 ohms.
W.S.
von Analog (Guest)
Do you remember the thype of this offset?
How constant is the offset voltage of these opamps? is it suficciant to
mesure offseton open circuit and subtract, or does it change much over
time? I thought of a 10kOhm shunt? Mesure Voltage before and the voltage
drop over shunt. So effective Voltage can be calculated.
How would you design this?
von Ulrich (Guest)
The offset of these OPs is highly temperature dependent, similar to the
leakage current of a diode. So one has to keep the temperature low and
constant.
Just a Shunt is usually not a good option. The voltage Drop over the
shunt will be to large and change the voltage.
The typical circuit is a transimpedance amplifier with one of the extra
low bias OPs. Choose the feedback resistor as large as resonabe possible
(e.g. in the 10 M range). For larger currents (e.g. more than 0,1 µA) a
second range is probably needed.
von Analog (Guest)
Hi ulrich
many thanks
I thougt about a solution with a shunt and measuring the voltage before,
but since I know the current and the shunt value i can calculate the
voltage drop and suptract it from the mesured Voltage.
with the transimpedance amplifier I would need a resistor of about 1GOhm
to get a mV Voltage at 1pA so i could even mesure below 1pA. How big are
leakage currents on pcb etc? Would you recommend such a high resistor?
And what opamp type has enough input resistance?
von Ulrich (Guest)
Leakage currents on the PCB are a problem. You may want to use extra
isolation standoffs and have the critical pins free in the air, not on
the PCB. If one wants the PCB, keep it really clean and use active
shilds.
The input impedance of MOSFET input OPs is large enough (e.g. 10^12 Ohms
range) - leakage from internal protection diodes may be a problem at
higher temperature. You probably won't need 1 G Ohm as feedbach, because
one can measure less than 1 mV. It should be OK to resolve something
like 10-50 µV. So something like 10 M to 100 M is enough. This also
gives more range with one resistor. With the OP its also important to
look for low drift and low frequency noise, not only for extremly low
bias currents.
So even something like the old ICL7650 may be an option - not the lowest
bias, but low drift and LF noise. Here even less than 10 M is OK as a
resistor.
von Analog (Guest)
I had the Idea to use a Fluke 189 Multimeter, unfortunately I cant
change the Integration time of this device. (around 1/4 sec).
However since this device is a Multimeter and not a precision
Voltagemeter i think I should have at leaset 1mV in order to mesure
precisely. Do you see any Problems using a 1G resistor? (for the range I
can also switch to 100M). I will probably build the circuit without PCB.
Ive seen, that the ICL has a relatively high offest Voltage of 1uV.
Which affects the Voltage measurement.
