Forum: FPGA, VHDL & Verilog Generating a signal (a VHDL description) with a well-defined frequency in a FPGA
von issam s. (Company: uqtr) (isamel85)
Hello,
In fact, I'm working on a project that aims to put a communication
platform to interact with hydrogen sensor wirelessly.
The platform consists of an evaluation board from Xilinx ML505 (on which
there is a Virtex 5) which will implement the baseband digital
processing and another board (Software Defined Radio) for the analog
front end that includes the blocks needed (modulator / demodulator,
filter, LNA, PA, local oscillator) to communicate on the UHF band (900
MHz).
The platform requires a 12-bit DAC and an ADC 12-bit to adapt the two
boards.
So I need help to generate a baseband signal (VHDL description) with a
defined frequency, otherwise, I have trouble to describe the signal
generator in VHDL
von martin (Guest)
Look for  cordic
