Forum: FPGA, VHDL & Verilog Verilog force assign
Author: Bruno (Guest)
I face a problem when I try to force a signal in my Verilog testbench
My v file is:
module test(I);
  input I;
  wire tmp;
  wire NB;
  assign NB = I;
  assign tmp = NB;
endmodule
My testbench is:
module tb();
reg in;
test test(in);
 initial begin
      in = 1;
      #10;
       force tb.test.I = 1'b0;
      #20;
       release tb.test.I;
      #20;
      $finish;
   end //initial
endmodule // tb_scu
When I look at the simu result, signal I is following my force/release
but NB (and therefore tmp) is not.
I am really unable to figure out the problem.
Does anyone see something wrong or have an idea?
Tahnks a lot.
Br
Author: Harald (Guest)
Bruno,
in case this works
test test(in);
 initial begin
      in = 1;
      #10;
      in = 0;
      #20;
      in = 1;
      #20;
      $finish;
   end //initial
I also would assume that this is a simulator issue. I don't see any
reason why the forced value should not be propagated through the assign
statement. What simulator are you using?
Harald
Thanks for your answer.
Yes your piece of code works.
I was using iverilog,
I tried with cver, it works now.
Then it is a icarus verilog simulator related issue.
Thanks a lot fo your help !
  • [vhdl]VHDL code[/vhdl]
