Forum: FPGA, VHDL & Verilog Using async signal
von Alessio (Guest)
Hi, i'm new to VHDL, i have this problem:
i've an async signal, called REQUEST, and into my process, if the
counter arrives to 5 and if the REQUEST signal went 1 in the previous
period of clock, i must do something. my problem is that REQUEST is
asynchronous, and its period should be less long than clock's period, so
i can't check it every positive edge of clock with the usual clock'event
and clock='1'….
how can i solve this problem? thanks!
Lets say these are your signals:  (X=signal change)
CLK   .-------.         ,-------.         ,-------.         ,-------.
CNT    X     3           X     4           X      5          X
REQUEST   when does it get active?   ^here     ^or here
> and its period should be less long than clock's period, so i can't
> and clock='1'….
You can store a pulse in a signal shorter than your clock cycle in a way
like this:
http://www.lothar-miller.de/s9y/archives/19-Kurzer-Spike-in-Puls-umgewandelt.html
But even a trick like this doesn't help you with your problem of clock
donaim crossing. As you describe it, I see no chance to react reliable
in less than one clock cycle...
von Alessio (Guest)
i don't know when request go 1, it's the problem…
i think also that the link contains the solution for my problem, thanks!
von Sim (Guest)
check the signal with a much faster clock and store it with an flip
flop. Is that no option?
Or use the request signal in the following way "request'event" and set a
flag.
Sim
