Forum: FPGA, VHDL & Verilog type conversion of a custom enumeration type
Author: M. R. (rojo)
I defined an enumeration type ("reg") in a package header:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
type reg is (R0, R1, R2, R3);
...and a conversion function which converts type "std_logic_vector" to
my type "reg":
function CONVTOREG (DATA :std_logic_vector) return reg;
In the body of the package I have the corresponding implementation of
this conversion function:
  function CONVTOREG (DATA :std_logic_vector) return reg IS
    variable result :integer;
      begin
       result := CONV_INTEGER(unsigned(DATA));
      return reg'VAL(result);
  end function;
This works fine. Now I need another conversion function which converts
the type "reg" back to std_logic_vector" which is declared like this:
function CONV_REG_TO_STDLV (DATA :reg) return std_logic_vector;
But I don't know how to implement that since there is no type conversion
which accepts my enumeration type. Has anybody an idea how to do that?
Thanks a lot!
Best regards.
M.R.
Author: user (Guest)
this will do it:
  return std_logic_vector(to_unsigned(reg'pos(DATA),2));
The 'pos attribute helped me.
Thanks a lot!
Best regards.
M.R.
  • [vhdl]VHDL code[/vhdl]
