Forum: FPGA, VHDL & Verilog All Purpose sign extension VHDL?
Author: yu (Guest)
Hi, I was just wondering how it would be possible to make an all purpose
sign extension entity in VHDL.
So I created this sign extension entity but it will only work if the
input is 6 bits long. If I put in an input that was say 3 bits long. It
wouldn't work. Is it possible to build a SEXT that doesn't have
limitation on input bits?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity SEXT5_0 is
  port ( data_in : in std_logic_vector(5 downto 0);
         data_out : out std_logic_vector(15 downto 0));
end SEXT5_0;
architecture behavioral of SEXT5_0 is
begin
  process (Input)
begin
  data_out(5 downto 0) <= data_in;
  data_out(15 downto 16) <= (15 downto 6 => data_in(5));
end process;
end behavioral;
> Is it possible to build a SEXT that doesn't have limitation on input bits?
Take the numeric_std package instead of the old and obsolete
STD_LOGIC_ARITH and STD_LOGIC_UNSIGNED. And then simply write:
data_out <= std_logic_vector(resize(unsigned(data_in),data_out'width));
If you want to make your solution more generic then write it this way:
  data_out(data_in'range) <= data_in;
  data_out(data_out'left downto data_in'width) <= (data_out'left downto data_in'width => data_in(data_in'left));
  • [vhdl]VHDL code[/vhdl]
