Forum: ARM programming with GCC/GNU tools Debugging cortex-m3 in GDB with J-Link causes SIGTRAPs
Author: Artem Pisarenko (artymen)
Trying to debug LPC1768 project (with FreeRTOS) on hardware with J-Link
GDB Server I encountered problem: debugger receives SIGTRAP signal on
instruction SVC 0 (in function vPortStartFirstTask). As if breakpoint
catches. I can't understand why. I'm trying resume but it triggers
again. On single step it hangs and j-link shows a lot of these events
(target halted, started CPU, target halted, etc.). Moreover, I tried
standard example CORTEX_LPC1768_GCC_RedSuite from FreeRTOS. The same.
But IAR projects work fine. I'm using Yagarto toolchain. (Tried both old
arm-elf and latest arm-eabi versions). gdb commands I specified in
Eclipse debug configuration:
monitor endian little
monitor flash device = LPC1768
monitor flash download = 1
monitor flash breakpoints = 1
monitor speed 1000
monitor reg r13 = (0x00000000)
monitor reg pc = (0x00000004)
Also I checked Reset and Delay and Halt options. Set breakpoint at: main
and Resume also set and works fine (Program stopped at main, then I
resume and it stopped on SVC 0)
I worked with ARM7TDMI earlier and didn't experienced such problems.
I figured out what was wrong. Target didn't resetted. "Reset and Delay"
and "Halt" options have no effect actually. It's a bug/feature in "C/C++
GDB Hardware Debugging" (version 7.0.0.201009241320) feature of Eclipse
CDT. You have to specify "monitor reset 0" command manually.
It's a pity because I could observe it easy as all being watched
closelly in gdb server messages window and didn't noticed that
"Resetting target" message doesn't appears anywhere :)
Author: Mel (Guest)
I had this same problem when moving from the integrated st-link debugger
(on my STM32 G-Eval board) to using the J-Link cable
Stuck at "SVC 0"
I had the debugger configuration check boxes for "halt" and "reset and
delay" checked and also had "monitor reset halt"  in the initialzation
box. But I changed it to "monitor reset 0"  and now it comes out of
reset correctly.
