library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; entity nam is port (a : in std_logic_vector(7 downto 0); b : in std_logic_vector(3 downto 0); c : out std_logic_vector(3 downto 0)); end nam; architecture ban of nam is begin process(a,b) variable p,h :std_logic_vector(8 downto 0); variable m :std_logic_vector(4 downto 0); variable k:std_logic; begin m(4):='0'; m(3 downto 0):=b; p(8):='0'; p(7 downto 0):=a; p(8 downto 4):=p(8 downto 4)-m; k:=p(8); p(8 downto 1):=p(7 downto 0); h:=p; for i in 0 to 4 loop if(k='0') then h(0):='1'; h(8 downto 4):=h(8 downto 4)-m; else h(1):='0'; h(8 downto 4):=h(8 downto 4)+m; end if; k:=h(8); h(8 downto 1):=h(7 downto 0); if (i=4) then c<=h(3 downto 0); end if; end loop; end process; end ban; c=quotient c=a/b here i have written one program for non restoring division....but am getting the quotient as three....
You run a division of 8 bits by 4 bits and you return 4 bits as the
result.
1 | a : IN std_logic_vector(7 downto 0); |
2 | b : IN std_logic_vector(3 downto 0); |
3 | c : OUT std_logic_vector(3 downto 0) |
So one fairly simple question: What would you expect as result when you calculate 16/1 or 32/2 or 33/2? How will these results fit in 4 bit?
that one is a limitation....but i have tried 32 by 4 and 32 by 8 the resuts were 3 in both cases.......what will be the problem...anybody having another program for this non restoring division please send me.....
