Forum: FPGA, VHDL & Verilog Board recommendation for MLBS of min 60MHz
Author: Jack Jill (jackjill)
Hello there!
I need to generate a Maximum length binary sequence (MLBS) with an FPGA
for a project of mine, which I then have to modulate with a carrier
signal. The MLBS needs to be at least 60MHz and above frequency. I found
an old Spartan-3 starter kit and started working on it to try and
generate such a signal. The problem is that the oscillator frequency of
the board itself is just 50MHz. Hence its impossible to generate the
requisite signal of 60MHz.
There is a plethora of options available here and I am confused as to
which will the the most cost effective board that will serve my purpose.
I'd appreciate if someone guides me on to the right direction and helps
me out in this regard.
Regards,
Author: user (Guest)
use the internal pll/dll of the fpga to generate 60MHz from the 50MHz
The problem is that I need to generate an MLBS of at least 60 MHz i.e.
60MHz and above until probably 120MHz. Then I also need to generate a
carrier signal of say 200Mhz, modulate my MLBS onto the carrier and then
get the resulting signal from an output pin. This seems highly
improbable (at least to my weak knowledge) on a Spartan-3 starter Kit.
  • [vhdl]VHDL code[/vhdl]
