In VHDL, variable should make no delay between value assignment. But how about mix signal and variables? In code below, X and Y are variables and Z is output. Why the delay between Z and input A,B is 3 clocks? Why it's not 1 clock delay? Thanks in advance. ========================== process(clk) variable X,Y:std_logic; begin if(clk's event and clk='1') then Z<=Y; Y:=X; X:=A and B; end if; end process;
> Why it's not 1 clock delay? Becuase the variables are read before they are written, therefore they must be storing. > Why the delay between Z and input A,B is 3 clocks? Its not called delay, its latency... Play "FPGA" and do the process on your own:
1 | if(clk's event and clk='1') then |
2 | Z<=Y; -- with the clock Z becomes Y |
3 | Y:=X; -- AFTER THAT Y becomes X |
4 | X:=A and B; -- AFTER THAT X becomes A*B |
5 | end if; |
The two AFTER THAT are the two additional clock cycles... If you would turn it around ther would be no additional latency:
2 | X:=A and B; -- FIRST X becomes A*B |
3 | Y:=X; -- THEN Y becomes X |
4 | Z<=Y; -- AND FINALLY Z becomes Y |
5 | end if; |
Because then the variables are not storing...
- Variables are assignmed sequentially, so order of assignment matters - Signals are assigned "all together" at the end of a time tick so this is what happens after input A or B changes: 1st clock event Z is marked not to change, as variable Y has still the old value Y is assigned the old value of X (as it has not changed so far) X is assigned the new "A and B" 2nd clock event Z is marked not to change, as variable Y has still the old value Y is assigned the value of X as from 1st clock event X is assigned the new "A and B" 3rd clock event Z is marked to get the value of Y at the end of the process Y is assigned the value of X as from 2nd clock event X is assigned the new "A and B" Z is assigned the value of Y Here we are...
Very clear clarification. Thank you all very much!
