Forum: µC & Digital Electronics run the example(mini3250)
von Brittany S. (brittany_snow)
I lend a Devkit3250 with 4.3" LCD, first I would like to test sample
program & load it on the kit module.I am using ubuntu 8.10 & I have
installed Arm-linux-gcc-4.3.2.
I have compiled the sample code, but I have problem to run it on the
board mini3250.
here the result has shown... (root terminal console):
[root@arm-linux /myFile]# ls
button         com            hello.desktop
buttoncp       hello          hello~1.des
[root@arm-linux /myFile]# ./hello
-sh: ./hello: not found
[root@arm-linux /myFile]# ./hello~1.des
./hello~1.des: ./hello~1.des: 1: [Desktop: not found
./hello~1.des: ./hello~1.des: 5: Example: not found
./hello~1.des: ./hello~1.des: 9: Name[en_US]=Hello: not found
[root@arm-linux /myFile]# cat hello~1.des
[Desktop Entry]
Version=1.0
Encoding=UTF-8
Name=Hello
Comment=An Example Program
Exec=hello
Icon=Hello
Type=Application
Name[en_US]=Hello
[root@arm-linux /myFile]# ./hello.desktop
-sh: ./hello.desktop: Permission denied
[root@arm-linux /myFile]# cat hello.desktop
[Desktop Entry]
Exec=hello
Icon=Hello
Type=Application
Name=Hello
[root@arm-linux /myFile]# ./button
./button: ./button: 1: Syntax error: "(" unexpected
[root@arm-linux /myFile]# ./com
./com: ./com: 1: Syntax error: "(" unexpected
Please help me...
von Wastl (Guest)
As in the log mentioned, there are atleast two unexpected brackets.
You should check for these errors, but without the complete program it
is impossible to give an exact solution.
regards
I have checked it ,but still is wrong.
Do you used this board before?
von argl (Guest)
chmod the file to give you execution rights
chmod u+x hello.desktop
check if it is an executable by
file hello.desktop
I really don't know what to do now. and I will follow the CD to make the
log and have a try. If I do it sucessfully, I will tell you. Acctually,
I have got some ideas from the webs: www.armkits.com. I will try.
Ok, I get the answer. It is my mistake that I didn't use the cross
compil tool along with the CD. And I have get what I want now.Thank you
for all of you and Embest!
