Forum: µC & Digital Electronics Mikrocontroller with Uart
von Dave (Guest)
Hello,
I am looking for a microcontroller with 4 UART interfaces. Does anyone
know of one?
The best one from the Atmel family.
thanks for the help
von Spess53 (Guest)
Hi
ATMega640/1280/2560
MfG Spess
von Dave (Guest)
Thank you!
What is the difference between ATMEGA 1280V-8AU and ATMEGA 1280-16AU ??
Is one with 8 MHz and the other with 16 MHz?
von rico (Guest)
exactly!
but you can also use software uart for your porject.
greets!
von Dave (Guest)
hello,
I have a little problem. I want to use this Display KIT160-6 with this
µC Atmega1280. So I have connected the µC with a Max232, but where is
RTS/CTS?.
von Peter D. (pdiener)
The uart in the ATmega does not have hardware handshake. You have to
implement RTS/CTS functions in software by using 2 arbitrary port-pins.
von Dave (Guest)
Can I connect two microcontroller via UART with each other?
von Anja (Guest)
Yes, if both are powered by the same power supply.
Otherwise if you power off one of both controllers the powered off
device will be powered by the TXD-Line of the other controller. This can
lead to latch-up effects when the powered off device is switched on
again.
To avoid this you can use CD4050B gates on each RXD line or use series
resistors to limit the current to below 0.5mA (which is usually "safe").
Of cause you can use a MAX232 transceiver to avoid latchup-effects too.
with best regards
Anja
von Brittany S. (brittany_snow)
know of one?
How about SBC9261-I based on Atmel AT91SAM9261S processor?
Or SBC6300X based on Atmel AT91SAM9263 processor?
They are all good to use.
von Dave (Guest)
I want to build the circuit because of AVR465 and have a little problem.
I would like to not use the ATmega88 in SMD and DIL. But unfortunately
this has a different pinout. Do you have to rewrite this program?
