Forum: FPGA, VHDL & Verilog Igloo Nano I/O tri-state buffer
von kamran q. (kamran_q)
Hello,
I am using Igloo Nano AGLN030Z. I would like to know if igloo nano has
Tri-State, input output buffers. I would really appreciate if some one
points out the specific Block used for this purpose in Libero IDE.
Looking forward.
Kamran.
: Moved by Moderator
> I would like to know if igloo nano has Tri-State, input output buffers.
Even the simplest and oldest GAL has tristate buffers, so I would expect
a much more recent technology having such buffers too.
But why not just searching the datasheet for "tristate"?
Hello Lothar,
Yes I did.
I perhaps wasn't clear enough in my post.Let me explain.
I did find tristate buffers in the Datasheet, but I also want them to be
bidirectional.
I have one controller talking to another controller via a cpld(igloo
nano). Now in this basic communication I want following scenario:
1: Device one sets a register field to 1 to send data. Other device gets
ready to read data.
2:Device 2 communicates with device one in the same way.
3:Other wise both show high impedance at output.
This all shall be done using only two I/O pins.
Kamran Qureshi.
> to be bidirectional.
Thats usual behavior. In VHDL you write this and you will get a
bidirectional buffer:
   portpin  <= signal_out when enable='1' else 'Z';
   signal_in <= portpin;
>   Other device gets ready to read data.
Hmhmhmmmmm...
This isn't very polished. How does this
> a register field
and
fit together?
Why not using a kind of RS232?
> 3: Other wise both show high impedance at output.
You always should/must have one driver (or at least a pullup/down
resistor) on a tristate signal. Otherwise this signal can float and you
will get a high current in both input stages.
