Forum: ARM programming with GCC/GNU tools Help required to use arm-hitex-elf-ar
von Tameezuddin (Guest)
Hello there,
Recently, I want to create static library using HITEX ARM GNU compiler.
I am using arm-hitex-elf-g++.exe & arm-hitex-elf-ar.exe to compile set
of .cpp files and from these resultant object files, I want to create
static library to make a binary image to be deployed on ARM board.
Following is the syntax, I am using
GG = arm-hitex-elf-g++.exe
CC = arm-hitex-elf-gcc.exe
AS = arm-hitex-elf-as.exe
LD = arm-hitex-elf-ld.exe
OC = arm-hitex-elf-objcopy.exe
AR = arm-hitex-elf-ar.exe
CCOPTIONS = -DJUP_1 -I..\ -I..\.. -mcpu=arm968e-s -c -gdwarf-2 -MD -Wall
-O3 \
-mthumb-interwork -mapcs-frame -fsigned-char -mlittle-endian -marm \
-fomit-frame-pointer -fno-rtti -fno-exceptions -msoft-float
all: clean xyz.a
{..}.c.o:
   $(CC) $(CCOPTIONS) -xc -o $*.o $*.c
{..}.cpp.o:
   $(GG) $(CCOPTIONS) -xc++ -o $*.o $*.cpp
clean:
   -@echo Cleaning up files ...
   -@erase *.d
   -@erase *.o
   -@erase *.a
OBJS = \
1.o \
2.o \
3.o \
COMDEPS = \
..\..\1.h \
..\..\2.h \
..\..\3.h \
LCLDEPS = \
..\a.h \
..\b.h \
..\c.h \
$(OBJS) : $*.cpp $(COMDEPS) $(LCLDEPS)
xyz.a : $(OBJS)
  $(AR) -mac -v  xyz.a $(OBJS)
when I am using the above command, it's giving me following error:
"File format not recognized"
Also, I tried to give emulation option elf32-littlearm as following
sytax
$(AR) elf32-littlearm -mac -v  xyz.a $(OBJS)
It's giveing me syntax error.
Help in this regard is highly appreciated
Note: the above code is from the makefile I have writtena and I am using
nmake to execute this makefile.
Regards,
Tameez
