Forum: ARM programming with GCC/GNU tools Problem with stdint.h inclusion
von Olivier D. (olivierd)
Hello,
I am currently trying to put up in place an Eclipse-based tool chain on
my Mac with this tutorial:
http://salvatoremenendez.blogspot.com/2011/08/mac-os-eclipse-openocd-stm32-arm-cortex.html
which seems quite nice. Everything went fine, I installed Eclipse 3.7.0,
OpenOCD 0.4 and yagarto 4.6 but one thing doesn't work.
As the tutorial tells on page 3, i use a project coming from the yagarto
website to test the toolchain. The thing is, the line #include
<stdint.h> in the main file (and other files as well)  produces a
"Undefined reference to <stdint.h>" warning. Of course this results in a
lot of errors which is quite troubling.
I'm not really a professional in the use of makefiles but I gave it a
try, I can't find the solution to this. So if anyone knows how to solve
this, I thank you in advance!
von Helfer (Guest)
Maybe the path to the include files in the toolchain is not set
properly.
1) Check with file search whether the files are on your harddisk in one
(or more) folders of the yagarto toolchain
If not you have another problem
2) Check the setting of the include paths and compiler options in
Eclipse
http://help.eclipse.org/galileo/topic/org.eclipse.cdt.doc.user/tasks/cdt_t_proj_paths.htm
http://www.alteraforum.com/forum/showthread.php?t=19940
If you are not sure, you can show us the commandline when invoking the
compiler as well as the messages during the build (compile) action.
Thanks for the help, I think it worked! I used the general include
repertory in yagarto, it removed all of the warnings and errors due to
data types. I'll see if it worked when I get my evaluation board on
monday, but it seems to compile fine!
Thanks!
