Forum: FPGA, VHDL & Verilog Build an I2C protocol using systemverilog
Author: Fitrahhadi S. (fitrahhadi_s)
Hi.. Im newbie in FPGA(2 weeks). i've tried to build an I2C protocol
using Sytemverilog. Well my design is based on i2c timing diagram but
i'm not sure whether it is correct or not. However, i've already
simulated using Modelsim and im quite happy with the result. Well the
problem is why the result is different to simulation? FYI: Im using
Quartus software (Altera based) and the FPGA board is De0-nano from
Terasic. I'm glad if anyone give me a respond to my problem. Thankyou.
This is my coding.
//i2c as Master
module i2cprotocol (inout SDA, output logic SCL, output logic [7:0]DATA,
input clk);
logic SDA_Utopia ;
logic [4:0] num;
assign SDA = SDA_Utopia;
always
begin
 i2c_start();
 i2c_write(8'hA0);
 i2c_write(8'h00);
 i2c_write(8'hA1);
 i2c_stop();
end
task i2c_start();
@(posedge clk);
SDA_Utopia <= 1'b1;
SCL<= 1'b1;
@(posedge clk);
SDA_Utopia <= 1'b0;
SCL <= 1'b1;
@(posedge clk);
SDA_Utopia <= 1'b0;
SCL <= 1'b0;
endtask
task i2c_stop();
@(posedge clk);
SDA_Utopia <= 1'b0;
SCL <= 1'b1;
@(posedge clk);
SDA_Utopia <= 1'b1;
SCL <= 1'b1;
endtask
task i2c_write(input logic [7:0] data); //data 8-bit
for(num=0;num<=8;num++)       //7 bit-Address
begin
@(posedge clk or negedge clk);
  if (num == 8)
    begin
    SDA_Utopia <= 1'b0; //1-bit ACK
   SCL <= 1'b0;
    end
    else
    begin
    SDA_Utopia <= data[7-num];
    SCL <= 1'b0;
    end
    SCL <= 1'b1;
    SCL <= 1'b0;
  end
  num = 0;
endtask
task i2c_read(output logic [7:0] data_out, input logic ACKNACK);
  begin
     if (num == 8)
        begin
        SDA_Utopia <= ACKNACK; //1-bit ACK
        SCL <= 1'b0;
        end
        else
        begin
        data_out[7-num ]<=SDA;
        SCL <= 1'b0;
        end
    SCL <= 1'b1;
    SCL <= 1'b0;
  end
   num = 0;
endtask
endmodule
Subchan
Author: Lattice User (Guest)
In standard Verilog your code will only work for simulation, as you use
sequenziell contructs, (task, @() outside always). Hardware is parallel
and there is no such thing like a sequenziell loop or waiting on the
next clockedge with @(). In other words you need to implement a state
machine.
Disclaimer: I can't speak for Systemverilog and also not for Quartus,
but i think my answer applies anyway.
I agree totally.
I do not know SystemVerilog or even Verilog, but I know hardware and
VHDL in depth. What I see here is C with a Verilog syntax. Whats
completely wrong is the way of thinking, the mindset:
You are thinking sequential "C" (Line 5 happens after line 4...),
not parallel "hardware" (all of it happens always all the time...).
At this point it does not make any sense to give you any further
hints...
Next step for you is to learn "hardware": do the "hello world!" of
hardware (a blinking LED, a chasing light)!
Author: durga (Guest)
where is the address and acknowledgement handling mechanism
  • [vhdl]VHDL code[/vhdl]
