splee splee wrote:
> Two questions here:
> 1. So the two codes below essentially are identical to each other
> (synthesized circuit)?
They are exactly the same.
Additionally this results in exactly the same hardware (just wiring...)
1 | architecture Behav1 of simpleBuffer is
2 | signal b : STD_LOGIC;
3 | begin
4 | process (a)
5 | begin
6 | b <= a;
7 | end process;
8 |
9 | process (b)
10 | begin
11 | c <= b;
12 | end process;
13 | end Behavioral;
And also this:
1 | process (a,b)
2 | begin
3 | b <= a;
4 | c <= b;
5 | end process;
is the same like this:
1 | process (a,b)
2 | begin
3 | c <= b;
4 | b <= a;
5 | end process;
> 2. In a process statement, a signal only gets its assigned value after
> the process suspends, eg. in Behav1, b only gets the value of a after
> the process suspends.
> Why would a synthesis tool make it such complicated?
Because thats the behaviour defined in the language description of VHDL.
> I mean, why can't a signal get the value immediately,
> just like variable and like in C program?
If you use signals and a clock you can be sure: theres no need to
observe the order of the instructions, because throughout the whole
process the signal doesn't change its value. So this:
1 | signal a,b,clk : ...
2 | :
3 | process (clk) begin
4 | if rising_edge(clk) then
5 | b <= b+1;
6 | if (b=4) then
7 | a <= a+1;
8 | end if;
9 | end if;
10 | end process;
is exactly the same like this:
2 | :
5 | if (b=4) then
6 | a <= a+1;
7 | end if;
8 | b <= b+1;
9 | end if;
10 | end process;
With variables you must be aware, where to add statements.
> What's the point of making things difficult?
Its not difficult, its just different... ;-)
