Forum: FPGA, VHDL & Verilog help with multiplier
Author: sreeram sam (sresam89)
the program is for a  simple multiplier using addition of the partial
products. i find problem only with final addition part pls help me out
architecture Behavioral of new_twin1 is
type arr is array (3 downto 0) of std_logic_vector(3 downto 0);
type arr2 is array(4 downto 0) of std_logic_vector(7 downto 0);
signal and_1:arr:=("0000","0000","0000","0000");
signal t6:arr2:=("00000000","00000000","00000000","00000000","00000000");
signal temp:std_logic_vector(3 downto 0);
signal sum:std_logic_vector(7 downto 0):="00000000";
begin
process(clk)
variable z,t,k:integer;
variable t2:std_logic_vector(3 downto 0):="0000";
variable t7:std_logic_vector(7 downto 0);--:="00000000";
begin
for i in 0 to 3 loop
t6(i)(7 downto 0)<=("00000000");
end loop;
 for j in 0 to 3 loop
  and_1(i)(j)<=(x(i) and y(j));
 end loop;
end loop;
t6(3)<=  "0000" & and_1(0);
k:=0;
for i in 2 downto 0 loop
 t6(i)<=t2( i downto 0) & and_1(k+1) & t2(k downto 0);
 k:=k+1;
end loop;
 t6(4)<=t6(4)+t6(i);
end loop
----just tried this alternative which too dint work---
--  t6(4)<=t6(0);
--  t6(4)<=t6(4)+t6(1);
--  t6(4)<=t6(4)+t6(2);
--  t6(4)<=t6(4)+t6(3);
end process;
end Behavioral;
the final for loop for addition is giving me a gig-up.when i try to
access one variable inside the array am able to retrieve it but while
adding to the same, the total value tends to undefined(XXXXXXXX).
please suggest any modification
thanks in advance
Author: Duke Scarring (Guest)
Can you provide a working testbench?
Duke
> Duke
i did not get you
moreover i solved it by changing the data types for t6 to variable
rather using signal
> process(clk)
Your process isn't sensitive to the clock.
So your sensitivity list is WRONG and therfore the whole simulation is
completely WRONG.
> rather using signal
Sounds like "I'm digging for gold, but don't know where"....
Lothar Miller wrote:
>> process(clk)
> completely WRONG.
>> rather using signal
SORRRY MORE OR LESS THE SAME :)
  • [vhdl]VHDL code[/vhdl]
