Forum: ARM programming with GCC/GNU tools keyboard HID example for WinArm
von libed (Guest)
HI
Im using an exampe
(http://gandalf.arubi.uni-kl.de/avr_projects/arm_projects/at91_usbfw_core101_hid100_gcc_20070310b.zip)
which is keybord HID implementation. Data transfer from device to host
works fine, but in second direction (from host to device) not. The
project compiles with no errors.
Function which read data from host call's other 'callbacks' function:
   unsigned char bStatus;
    do {
        bStatus = KBD_ReceiveReport(&sKbd, (Callback_f) ReportReceived,
0);
    while (bStatus != USB_STATUS_SUCCESS);
static void ReportReceived()
    if (ISSET(sKbd.sOutputReport.bmLeds, 1)) { //read incoming buffer
        LED_ON(LED_MEM);
    else {
        LED_OFF(LED_MEM);
but in my program the void ReportReceived() function is never executed.
In program for USB data packet monitor ("USBTrace") i can see that the
OUTPUT packet are sending correctly.
what is wrong with that project. Has anyone tested it?
von Martin Thomas (Guest)
At the time when I ported the code from an Atmel example for IAR/EWARM-
to the GNU/arm-*-gcc-toolchain I did just a few tests to verify that
keyboad- and mouse-emulation does work. I have never made a "real world"
project with HID and AT91SAM7. In the meantime Atmel published a lot
more code. There is a HID-example in the AT91 software package. Search
atmel.com for the at91sam7s-ek, in the download-section of the
eval-board-page you will find the software-package and in it several USB
examples. The GNU toolchain is supported, so no porting is needed.
For HID there is also interesing code from ARM/Keil available in the
MDK-ARM-package (I just have an older eval-version here). Even if the
ARM/Keil-code can not be used because of the license the source might
give some "inspiration" (It has been for me when playing with HID on
targets from a different vendor).
von libed (Guest)
Thank you for reply,
Yes I found it, and works it fine. Now I must to understand many, many
code lines...
