Forum: FPGA, VHDL & Verilog help with SPI slave implementation in Verilog
Author: JCL (Guest)
I am working an embedded system where I have a micro-controller as the
SPI master and an Altera Max II CPLD as the SPI slave.  My slave
peripheral works correctly most of the time but every once in a while
the data is 1 bit off always in the same direction (ie. I expect a 2,
and get a 1):
The  CPLD clock is 2.048 MHz, SPI_SCK is 100 KHz
Any help is greatly appreciated!
always @(posedge OSC2048MHz)
        // SPI_SEL must be low to talk SPI
        if(!SPI_SEL)
        begin
           case(SPI_state)
              0:      // load the shift register
              begin
                // if there is data in the FIFO, load into shift
register
                if(!FIFO_empty)
                    begin
                       SPI_sr  <= FIFO_rd_bus;
                       FIFO_rd <= 1;
                    end
                else
                    // if the FIFO is empty, load the status
                    begin
                       PI_sr <= stat;
                    end
                    SPI_state <= 2'd1;
             end
            1:   // wait for SPI_SCK to go high
            begin
               if(SPI_SCK)
                    begin
                       SPI_MISO <= SPI_sr[SPI_sr_bits-1];
                       SPI_sr[SPI_sr_bits-1:1] <=
SPI_sr[SPI_sr_bits-2:0];
                       SPI_state <= 2'd2;
                    end
            end
            2:      // wait for SPI_SCK to go low
            begin
               if(!SPI_SCK)
                  SPI_state <= 2'd1;
            end
            3:      // should never get here
            begin
                SPI_state <= 2'd0;
            end
        endcase
    end
    else  // if SPI_SEL is high, reset the state machine bring the MISO
line low
    begin
            SPI_MISO  <= 1'b0;
            SPI_state <= 2'd0;
    end
    if(FIFO_rd)
        FIFO_rd <= 0;
end
Author: Br ian (brian_w17)
It is kind of difficult to debug without seeing a verifiable testcase
showcasing the error behavior.
However, one thing may help you: Two general rules for conditional
statements:
1) Use complete branching (i.e. if statements should have a paired else
statement, case statements should have default statement) lest ye infer
unintended registers.
2) Make sure all of your outputs are assigned in each branch (or use
default assignments). Again... unless you want to infer unintended
registers.
These are general guidelines. For the sake of completeness, I will say
that you don't always HAVE to do this... but this is a design decision
and you need to be aware of when memory will be inferred by the
synthesizer. If you don't know what i'm talking about, then be safe and
follow the rules.
  • [vhdl]VHDL code[/vhdl]
