Forum: FPGA, VHDL & Verilog query on verilog code
von pushpalatha G. (Company: Spanwave) (pushpalathavijendra)
hello,
         i have a doubt in verilog code..
 1)for a given 32 bit input if any one input is also x then return 1 or
else return 0 using functions how do i write a code for this in verilog?
please help
2) for a give 8 bit input if it is divisible by 4 then return 1 else 0..
donot use any arithmetic operators, loop statements ,case statements how
do i do this using functions in verilog
von ttt (Guest)
Homework? Which school?
von lkmiller (Guest)
This is just stupid homework. Generations of students figured it out
themself. The invoked process is called "learning"...
So far so good.
> how do i do this using functions in verilog
This is no special problem with verilog. How would you do it in (e.g.)
C?
I would do it this way:
Write down binary numbers and look for a pattern.
Which one is devideable by 4?
000000000 * this one
000000001
000000010
000000011
000000100 * this one
000000101
000000110
000000111
000001000 * this one
000001001
000001010
000001011
000001100 * this one
000001101
000001110
000001111
000010000 * this one
000010001
000010010
000010011
000010100 * this one
: and so on
111111000 * this one
111111001
111111010
111111011
111111100 * this one
111111101
111111110
111111111
Do you see the pattern?
No? Thats your problem.
Just a hint: if the lowest 2 bits are '0' the number is divideable by 4.
I'm a VHDL guy, but i would use a loop over the 32 bits and compare each
of them with 'x'. If one matches, i would terminate the loop an return
1.
von Arjun S. (arjun_s)
The following is the code..everything is fine but the final value is not
loaded into the stc..am attaching the simulation screenshots
`timescale 1ns / 1ps
module testy;
  // Inputs
  reg [15:0] a;
  reg reset;
  reg clk;
  reg ah;
  reg high;
  reg enable;
  // inouts
  wire [3:0] bts;
  //outputs
   wire [31:0] stc;
  // Instantiate the Unit Under Test (UUT)
  pract uut0 (
    .a(a),
    .reset(reset),
    .clk(clk),
    .ah(ah),
    .high(high),
    .enable(enable),
    .bts(bts)
initial begin clk =1; high =1; ah =1; end
always begin #10 clk=~clk; end
always begin #20 high=~high; end
30
always begin #40 ah =~ ah; end
31
  initial begin
32
    // Initialize Inputs
33
    a = 16'hfabe;
34
    reset = 0;
35
    enable = 1;
36
37
    // Wait 100 ns for global reset to finish
38
    #100;
39
        reset =1;
40
    // Add stimulus here
41
42
43
  end
44
      st uut1(
45
    .bts(bts),
46
    .stc(stc)
47
48
endmodule
: Edited by Moderator
Why the heck did you hijack a 3 year old thread with a completely
different topic?
> but the final value is not loaded into the stc..
Why should it? I cannot see any assignment to stc.
