Forum: ARM programming with GCC/GNU tools EABI problem
von dina e. (dina)
i was trying to build a frame buffer driver and I'm getting these
warnings:
WARNING: "__aeabi_d2iz"
[/home/dina/linux_shared/frame_buffer/Bg_ID3437/nm5625fb.ko] undefined!
WARNING: "__aeabi_dcmpeq"
WARNING: "__aeabi_d2uiz"
WARNING: "__aeabi_i2d"
WARNING: "__aeabi_dsub"
WARNING: "__aeabi_dcmpge"
WARNING: "__aeabi_dcmpgt"
WARNING: "__aeabi_dadd"
WARNING: "__aeabi_dmul"
WARNING: "__aeabi_ddiv"
WARNING: "__aeabi_dcmplt"
WARNING: "__aeabi_ui2d"
WARNING: "__aeabi_dcmple"
does anyone know the reason behind this?
thanks in advance.
von Duke Scarring (Guest)
Search your code for the missing symbols/functions (d2iz, dcmeq, etc.)
It look's like a missing (standard) library.
Duke
von dina e. (dina)
Hi Duke,
These symbols are not in my code. These are the result of the
compilation, it seems that some operations are interpreted in asm as
floating point operations. I think the problem is in the linking stage
but I'm not able to figure it out.
von Tecnologic (Guest)
ist a new Lib problem, caused by Codesourcerys new version. I recently
found some code to fix it on the web.
MfG
Tec
