Forum: ARM programming with GCC/GNU tools Show filename while compiling
von A. S. (aleksazr)
When I compile a larger list of files, i.e. a library,
MS VC shows something like "compiling source.c"
while GCC doesn't show anything, only warnings/errors.
Can I make GCC show the filenames?
Thanks
von Oliver (Guest)
As gcc is a command line tool only, you control which files are
compiled, by typing their names in the command.
If you use make with a makefile, gcc should be called individually for
each source file, and you cann see the command line for each source
file.
Oliver
I use the makefile, yes, with -s option (silent, probably).
Otherwise the screen is full of garbage (well, lots of unimportant
information).
MS VC, on the other hand, simply shows "compiling source.c",
and not the complete path and each and every single command line option.
Thats what I want, just a simple "compiling source.c".
It can't be done? (w/o changing the makefile, and adding echo)
von ... (Guest)
You can try something like this:
make -s CC="@echo \"compiling $@\"; gcc" CXX="@echo \"compiling $@\"; g++"
But better you change the makefile.
von olibert (Guest)
gcc is blank compiler but as mentioned already make is used
to process the files.
It displays already which file is being compiled like here..
make  all-am
make[1]: Entering directory `/home/blah/src/banner-1.3.2'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I.    -g -O2 -c banner.c
gcc  -g -O2   -o banner  banner.o
..but I think there is a misconception what make is intended for.
The approach is totally different compared to the MS stuff.
For instance make is also used for building sendmail config
files or NIS maps. These have nothing to do with compiling.
make provides a macro language to process files this includes
compiling but it is not limited to that.
You can edit the Makefile to add "compiling <blah"> but nobody
else would do so because the information is already provided
by a regular make run.
MS VC is the one that shows "compiling source.c", not the makefile.
GCC should be able to do the same, AFAIC.
But, I'll have to change the makefile, its not that hard after all.
von Johann L. (gjlayde)
No.
There is no reason for a diagnostic message for a file that compiles
fine.
http://gcc.gnu.org/onlinedocs/gcc/Translation-implementation.html#Translation-implementation
GCC does not print garbage, it's your Makefile setup.  Write a proper
Makefile to fit your needs.
von ... (Guest)
And also for MS, most messages came from MSBuild (slightly M$ equivalent
to make), not from the compiler.
von ... (Guest)
> There is no reason for a diagnostic message for a file that compiles fine.
For big projects it is sometimes nice to see the compiling progress to
estimate the time you have for your coffee and/or cigarette :)
But as you already said: "Write a proper makefile to fit your needs."
von Rolf Magnus (Guest)
Or use cmake to generate a Makefile. It does exactly that.
