Forum: Analog Circuits URGENT. Help on Power of Inverter.
von Karthiga G. (karthiga05)
Hi everyone. there is usually no power consumed in an inverter. Bt im
required to find out a condition that allows an inverter to consume
power. does anyone of u knw the condition? Thanks in advance!
if logic '1'is being applied, a logic '0' is what comes out and vice
versa. power is not consumed when both of this conditions are applied. i
would like to knw what is the condition required for power to consume.
> i would like to knw what is the condition required for power to consume.
First try this:
Switch both of the fets half way on...
So instead of applying a '1' or a '0', choose a '1/2' (with 5V supply
this is about 2.5V). A little hint here: have a look for the threshold
voltage of the fets.
And then step two:
What happens, when you switch from 0 to 1 and back very very fast?
Each time you have to cross the 2.5V.
And additionally: you have to charge and dirscharge parasitic capacitors
at the output (not drawn in the picture...)
Both effetcs consume power.
erm. im just learning theory. im only required to find out the
condition, is it this ---> significant power is only drawn whn the
transistors in the CMOS device are switching between on and of states?
Yes.
Lothar Miller wrote:
> Yes.
okay. great, thanks. :)
> Yes.
on and off meaning switching from 1 to 0 right?
Hmmm... You got something wrong... :-/
To keep it short: excessive power is consumed if you don't apply to the
input a steady 1 or a solid 0, but "something in between". This I meant
with the phrase "1/2"...
And this "something in between" you can achieve by simply leaving the
input unconnected. Then both of the gate will charge up to a
intermediate voltage, and both of the transistors will conduct corrent
from Vcc to GND. This case is widely known as a short circuit.
okay! got it. thanks so much! :)
actually what do you mean by 'simply leaving the input *unconnected*'
- leave it floating
- do not connect a external signal to it
- do not apply GND or Vcc/5V to it
> - leave it /floating/
okay! thanks again!
