Forum: ARM programming with GCC/GNU tools uint8_t to uint32_t pointer cast with arm-none-eabi
von Pawel (Guest)
I encountered another problem when I moved from arm-elf- to
arm-none-eabi-
The following code:
uint8_t *Data;
uint8_t  Idx;
*((uint32_t *)(Data+(6+Idx)))
would not work anymore.
My intention was to fetch 4 bytes pointed by Data (plus 6+Idx)
and interpret them as a 32-bit unsigned integer. It worked with arm-elf
but with arm-none-eabi only the lowest byte of the resulting 32-bit word
was correct. Could anybody help ?
Pawel.
von Klaus W. (mfgkw)
Maybe your uint8_t is not aligned on a /4 divisable address as probably
required for an uint32_t?
von Rolf Magnus (Guest)
Is the 32-bit-word you're trying to read properly aligned?
von Pawel (Guest)
Well, there is a 3/4 change that the data is not aligned. But how did it
work with arm-elf and does not work with arm-none-eabi ?
Pawel.
von (prx) A. K. (prx)
Different aligments.
