Forum: Analog Circuits zero-drift op amp
von Thomas (Guest)
Hi guys,
I often see that an op amp or an difference amplifier is zero-drift.
What does this mean? What makes an op amp zero-drift and another not?
Thanks!!
von toto (Guest)
It compensates the drift to zero. At a price though. See the datasheet.
von Thomas (Guest)
Which drift is this? Is it the output voltage, when the diff voltage at
the inputs is 0?
Which costs?
Thx
von toto (Guest)
The offset drift is zero. The cost is the chopping noise and that the
copping frequency should be avoided in the signal spectrum. The chopping
frequency is in the order of kHz.
von Thomas (Guest)
Sorry, but what is chopping noise?
von Arno H. (Guest)
Chopping noise is produced by Chopper-Op-Amps like ICL7650 due to their
working principle.
"Normal" OP-Amps are in the mean time as good as Choppers, see
AD8571/AD8572/AD8574 for example.
Arno
von Anja (Guest)
But the AD8571/AD8572/AD8574 are no "normal" Op-Amps they are chopper
stabilized Amplifiers
Best regards
Anja
von Arno H. (Guest)
Pardon, i read only the first sentences of the datasheet, where they
pointed out a huge difference between standard choppers and this AD874x
amps.
Arno
von Wolfgang Horn (Guest)
Hi, Thomas,
there may be several technical solutions to avoid drift.
(Earlier chopper amplifyer modulated the DC-diffence voltage at the
inputs into AC, amplified the AC driftless and modulated this back to
DC.
I'm using the ICL7650.
This amplifier of ingenious design is "chopper stabilized OpAmp". It
uses a chopper to sense the difference voltage at the inputs of the
OpAmp.
The OpAmp itself does not use chopping.
When the OpAmp is in a closed loop circuit, the difference should be
zero. But there is the offset voltage.
The chopper amplifier detects this offset and uses the biasing circuits
to minimize the difference.
One of the penalties occurs upon saturation of the OpAmp, caused by
overloading input signals.
In this case the chopper amplifier detects a severe difference voltage,
tries to minimize it - and produces a severe inbalance in the bias
circuit. After this event the chopper stabilized OpAmp uses some time to
find its stebility again.
You'll find further information in the data sheet.
Ciao
Wolfgang Horn
