Forum: ARM programming with GCC/GNU tools arm-elf-gcc path setting in eclipse
von Piyush P. (Company: none) (piyushpandey)
Hello guys
I am new to this forum and I have found it very fruitful for the ARM
related discussions so I posted my query here in hope that you guys will
help me out of this problem.
I have encounterd a big problem in my opinion but I think it would be a
little one for you guys.
well my problem is that I have successfullly installed the arm-elf-gcc
toolchain on my Ubuntu lucid system and have tested it and compiled the
program with it succesfully through commandline.
But now I want to compile the same program from the eclipse IDE and for
that I installed the gnuarm eclipse plugin from the sourceforge site and
try to compile the program but getting this error :
**** Build of configuration Debug for project demo2106_blink_flash ****
make all
Building file: ../main.c
Invoking: ARM Linux GCC C Compiler
arm-elf-gcc -O0 -Wall -Wa,-adhlns="main.o.lst" -c -fmessage-length=0
-MMD -MP -MF"main.d" -MT"main.d" -mcpu=arm7tdmi -mthumb -g3 -gdwarf-2
-o"main.o" "../main.c"
/bin/sh: arm-elf-gcc: command not found
make: *** [main.o] Error 127
here it is showing that arm-elf-gcc: command not found but I have
installed the compiler and it is specyfying the /bin/sh path for the arm
compiler whereas I have installed the compiler in the
/usr/local/gnuarm/install/bin/ path .
So my question is how can I configure the path of the compiler in the
eclip[se IDE as I have saw and checked many times that there is no way
or option to configure the path of the compilers , assemblers etc in the
eclipse .
So please tell me how to configure the path.
Thank you
von Lutz S. (fgs-bussard)
Well i´m not quite sure how its implementet in Linux, but in windows you
can add a PATH variable.
Right click on the Projekt you want to build --> Properties --> C/C++
Build --> Environment . Here can you add a Varriable called "PATH" and
the vaule is where to finde your compiler.
Best regards
Lutz
> Best regards
> Lutz
yeah thanks Lutz for your help
Now I can compile my program with the path of the compiler specified.
Thank once again.
Piyush Pandey
von rashad a. (rashad)
Dear sir,
 I have set Eclipse for ARm, using GNUARM tool chain on windows, i
imported sample project of lpc2148 led flash , in that there is one .s
(stratup assembly language file of lpc2148),
When i builds project,Make file compiles main.c to main.o ,but crt.s
file is not getting assembled and thus not getting further hex file,
Sir , please help me showing how to do the settings in c/c++ build
option of project ..
Hello rashad
This is your makefile problem , so check the makefile if the .s file is
there mentioned if not than mention it if mentioned than check the
syntax if it's ok or not.
do some googling about makefile writing and than proceed , hope you will
resolve your problem following the above steps.
cheers
Piyush Pandey
Hello Piyush;
Thank you for your help,
In my make file there is .s file ,but
Actually eclipse has a bug in helios version, it does not consider .s
(small s ), as a file type , I renamed it and changed to .S , Now
everything works fine , I got main.c->main.o,crt.S->crt.O and finally
.hex as output in release folder of ECLIPSE.
IT REQUIRED MANY CRUCIAL SETTINGS TO BE DONE IN C/C++ BULID OPTIONS OF
PROJECT IN ECLIPSE FOR GNUARM TO WORK...
Cheers ,
Rashad
von Harsh G. (Company: Sevya Multimedia) (harshgupta)
Hey,
I am linux user.
I am also getting the same error while configuring STM32 with Eclipse
Classic
Could you please let me know how to source the arm-elf-gcc compiler in
linux
-- Harsh
