Forum: ARM programming with GCC/GNU tools Makefile Example
Author: Rohan D. (rohan_d)
Hello ,
i m completly newbie to makefile , i want makefile example for flashing
LED or any simplee program u can suggest . i m using lpc2148 uC
Devlopment board . and WinARM GCC toolchain for creating HEX file on
Windows Platform .
the makefile examples given in sample folder are just hard to understand
me as i m newbie . i m attaching a sample program that is i had
downloaded from website . it is showing error . that specified path cant
find . when i look in to makefile i found that the code for programming
a HEX file was wrote in to that .
cant i just create only HEX file and then program it using Flash utility
if yes how ? what changes wiil i have make in "makefile" ?
the sample program attached contains C file and makefile .
dear moderator pls help me .
thanx and regards
Rohan
Author: iopet (Guest)
You have two solutions:
a) check on WinARM/Yagarto sites for examples, there are some, including
for your micro;
b) search the sf.net for    " GNU ARM C/C++ Development Support
0.5.3.201010141144" which will easy your job. This is a plug-in for
different tool chains, including WinARM and allows you to generate
managed make projects - aka you will not need to write your makefile.
Use this first, I hope you will enjoy it.
Regards,
Iopet
