Forum: ARM programming with GCC/GNU tools Problem while creating HEX file in WinARM using programmers notepad
Author: Rohan D. (rohan_d)
when i click on "Make All" command . i m getting below output . is it
the output should i get ? this is the sample programm from Examples.
what o/p should i get.
pls help.
this is the o/p i m getting.
///////////        o/p window       ///////////////
Creating load file for Flash: ledswitch.hex
arm-elf-objcopy -O ihex ledswitch.elf ledswitch.hex
You may have to bring the target in bootloader-mode now.
lpc21isp -control  ledswitch.hex com1 115200 14746
lpc21isp version 1.31
File ledswitch.hex:
  loaded...
  converted to binary format...
  image size : 476
Synchronizing...........................................................
.........................................  no answer on '?'
C:\WinARM\WinARM\utils\bin\make.exe: *** [program] Error 4
> Process Exit Code: 2
> Time Taken: 01:31
Sure? - it seems that "make program" has been selected.
So your message's topic is misleading: the output shows that the hex
file has been created
> File ledswitch.hex:
>   loaded...
>   image size : 476
> no answer on '?'
The utility lpc21isp gets called by make but can not snyc with the
microcontroller's the internal bootloader. lpc21isp is similar to
Flashmagic but does not offer a GUI. Read the Controllers manual,
section ISP, the NXP AppNote on using the LPC2000's bootloader and
output of lpc21isp -h for further information.
Author: vaibhav g. (vaibhav_g)
when i click on make all......
after loading the examples -lpc2106_blink_switch
the following error is generated.
***********output window********************
> "make.exe" all
> Failed to create process: The system cannot find the file specified.
> Process Exit Code: 0
> Time Taken: 00:00
HELP!
why is this error is coming......
Author: Oliver (Guest)
Progranmer's notepad is an editor, nothing else. It can be configured to
call external programms, i.e. make. This requires that PN is configured
to run the right make, that you have a suitable makefile in the right
folder, and that there exists a propely installed complete toochain for
ARM on your computer.
Do you have all this?
Oliver
yes i have all this.......
but still i m getting the above mentioned error .........
the path i have defined in control panel/system/advanced/enviornment
variable is also as per given in tutorials.................
plz help me on this.....
First thing is to check the toolchain.
Open a command window, navigate to the folder, where the makefile is
located, and type "make".
Oliver
heyy....
in the command window after navigating to the folder where make file is
located when i enter make...
then it shows
**no target specified and no make file found....stop****
but when i write dir command then it do show a executable file with name
make.......
i am not getting whats wrong with this thing......
HELP!!!
thanku
Please do not navigate to the folder, where the program "make" is
located, but to the folder, where the project you want to compile is
located.
There must be somewhere a file called "makefile". From this folder you
have to call make.
Oliver
heyy thanks oliver......
 sample code in my winarm is running now.....
one more query:
now as my sanmple project is running but if i want to compile my own
written C code ....watelse do i neeed along with a .c file to create the
hex code........do i neeed to write my own make file.....
do help!
you are saviour oliver.....
thanks again....
Probably yes. But to be very honest, writing your own C-programs for ARM
might require some more knowledge, as you have right now.
Maybe you want to check this document:
http://www.state-machine.com/arm/Building_bare-met...
Oliver
heyy oliver
wat are the topics you want me to read from that file you mentioned
above..........
i mean i cant read all pages of it.......
i just want to generate a hex code of my own written c code for ARM7,
nothing else...........
do reply!
thnks
That's your decision. I doubt that anybody in the world is a experineced
programmer of microcontrollers, but has never ever worked with "make"
before. And that means, you will have to read much, much, more, before
you can think about writing own C-programs for ARM7.
The good news (for me) is, it's not my problem. Sorry, im am out of the
discussion here. Good luck.
Oliver
no problemo oliver......
thanks 4 helping till now.....
just let me know if you get to know anything about it.....
it will be very helpful for me.....
vbhv
one more thing oliver ...
i think you may be misunderstanding my problem ....
i dont have to write a complex c code the ehing which i want is that
which can convert a very simple c code to hex code for arm7......
thats all.......
i hope you understnd what i am saying......
vaibhav
