Forum: FPGA, VHDL & Verilog How to initialize the memory in testbench when simulate a processor ?
Author: Min Peter (Company: NUDT) (peter_123)
Hi, everyone!
In my project, I use a procedure "file sim_vector  in stimulation.txt"
in the textio lib to read the stimulation file into "sim_vector", and
then I read the file line by line. In each line , I read the stimulating
data one by one, and put them one by one into the right port of the
memory(ram).
I think it too slow to input the program and data into the ram, and a
little bit complicated.
What I need is a procedure or method in VHDL, just like
"readmemb<memory, stimu.txt, @address>" in verilog, to inital my ram .
So could u help me?
Author: user (Guest)
you can use your function to write direct to the memory
type array(1024 downto 0) of std_logic_vector(31 downto 0);
signal memory : myarray := init_function("filename");
you only need to write a inif_function, which returns an array with the
memory content
Thank you!!^_^
I write a sram.vhd, and ues a tb_sram.vhd to simulate the sram. So, the
initial_function() should be write in the sram.vhd, or the tb_sram.vhd?
Author: Duke Scarring (Guest)
The initial_functionl() go to sram.vhd
If you synthesize your design for a FPGA target the memory will be
filled on startup with your program to.
Duke
hi!
you mean that I should design the init_function(stimulation.txt) in my
sram.vhd?
I wanna use: [file stimulation_file : text is in  "stimulation.txt"] ,
when I design the function, then read the stimulation_file line by line,
and put the value into each unit of my sram, so am I right?
> so am I right
Yes. Take a look at:
http://tams-www.informatik.uni-hamburg.de/vhdl/mod...
(and try to use ieee.numeric_std.all instead...)
Duke
  • [vhdl]VHDL code[/vhdl]
