Forum: µC & Digital Electronics AT91SAM7S RS232 SAM-BA Problem
von Nazmus S. (Company: Time & Space) (sakibnaz)
Hello.
I have made a simple Header Board with AT91SAM7S Chip. I am trying to
enable RS232 SAM-BA with my SAM7S Header Board. I have a working MAX232
Board and I am interfacing that Board with SAM7S debug Interface.
My Connection is below presented:
VDDIN, VDDFLASH, VDDIO Connected Together ---> 3.3V
VDDOUT, VDDPLL, VDDCORE  Connected Together ---> 4.7uF Cap ---> GND
PIN2 Ground --- GND
XTAL 18.432MHz Connected with XIN, XOUT (No Load Capacitor with XTAL)
MCU  DRXD (PIN29) ---> MAX232 RX & MCU  DTXD (PIN30) ---> MAX232 TX
I POWERED OFF my Board and Connect TST PIN with 3.3V then POWER ON for
10 Sec, then POWER OFF the Board, Disconnect TST PIN, then POWER the
Board again.
When I am running SAM-BA then it reports "Failed to Initialize FLASH
Accesses".
I am using SAM-BA v 2.10 (Downloaded from ATMel's web site), installed
on Windows XP SP2 .
Can anyone suggest me how to resolve the problem ...
Thanks in advance.
Regards.
Sakibnaz.
von Nico (Guest)
which board do you choose in sam-ba?
Hello.
Thanks for your reply.
My Header Board is of SAM7S64 and I am using USB-Serial Cable which is
installed as COM2. So I chooses on SAM-BA, COM2 and AT91SAM7S64-EK.
I am facing this error "Failed to Initialize FLASH Accesses" from few
days, please help me out ...
Awaiting for your reply.
Regards.
Sakibnaz.
von Nico (Guest)
do you have the evalboard from atmel (AT91SAM7S64-EK) or a custom board?
Hello.
My Problem is solved. Now I can able to program the MCU via RS232 Debug
Interface. Using the SAM-BA version 2.9 I can access the Bootloader.
I am using a custom Header Board of AT91SAM7S.
Thanks.
Regards.
Sakibnaz.
