Forum: FPGA, VHDL & Verilog VHDL_loop problem
Author: akshay bhandari (Company: jiit noida) (akshay_jiit1)
hi...
i was having some problem in running a while loop..even though i have
given condition still it goes infinite..help me out..Thanx in advance.
library ieee,work;
USE ieee.std_logic_1164.all;
USE work.myfunc.find;
USE work.myfunc1.diffarray;
USE work.myfunc2.subarray1;
ENTITY division IS
port(divi,divs : in bit_vector(7 downto 0);
quot,rema :out bit_vector(7 downto 0));
END ENTITY;
Architecture div of division is
signal cdivi,cdivs,msubarray,crema: bit_vector(7 downto 0);
signal hpdivi,hpdivs,maindiff,test1,i,tcount: integer := 0;
begin
process(divi,divs,cdivi,cdivs,maindiff,hpdivs,test1,msubarray,crema)
variable vsubarray,vdivs,vcrema : bit_vector(7 downto 0);
variable vhpdivi,vhpdivs,vhpdivs1,vdiff,test,count :integer :=0;
begin
vcrema := divi;
cdivs <= divs;
vdivs := cdivs;
while(vcrema > vdivs) loop
count := count + 1;
cdivi <= vcrema;
find(cdivi,vhpdivi);
find(cdivs,vhpdivs);
maindiff <= vhpdivi - vhpdivs ;
vdiff := maindiff;
hpdivs <= vhpdivs ;
test := hpdivs + maindiff ;
test1 <= test;
-- formation of subtractor array
for i in 0 to hpdivs loop
vsubarray(test - i) := vdivs(hpdivs - i);
end loop;
msubarray <= vsubarray;
diffarray(cdivi,msubarray,crema);
vcrema := crema ;
exit when count > 4;
--formation of quotient
end loop;
tcount <= count;
rema <= crema;
end process;
end div;
Author: Duke Scarring (Guest)
Can you deliver a testbench to your code?
hi..thanx for the reply..actually i am in IT branch.. so i dont have
much knowledge in VHDL..just know the basic syntax..i dont know wat test
bench is..basically i m implementing an algorithm for division using the
concept of vedic maths..m sorry..
Author: Vanilla (Guest)
Hi akshay bhandari,
you cant Do what you want it that matter,
Loop isnt a construct to control iterations like you do in software.
Loop meens your building paralel hardware.
Author: hhhh (Guest)
I think a "hanging" loop can happen in simulation, but I think a
synthesis tool would present some errors ;-)
OR
it won't function as expected.
Remember: don't use LOOP in VHDL if you are a beginner and you want to
synthesize your design
If you use it, use it carefully and double-check that your synthesis
tool likes LOOP and handles it the way you planned it.
It would be better to think about the hardware logic that does your job
and implement it the right way then (maybe there will be LOOP in it).
Author: Andreas Schwarz (andreas) (Admin) Flattr this
This way you might be able to write VHDL that runs in the simulator, but
never something that can be synthesized. Learn the basics of synchronous
processes in VHDL, and follow these rules:
http://embdev.net/articles/VHDL
  • [vhdl]VHDL code[/vhdl]
