Forum: FPGA, VHDL & Verilog <= and => operators
von superzanti (Guest)
What is the difference between the => operator and the <= operator. I
can't figure it out. i thought they were both signal assignment
operators for the longest time.
Thank you.
von hhhh (Guest)
Hi, the following statement maybe not a full declaration but for
beginners:
the <= operator assigns signals from the right to the left signal
the => operator maps signals e.g. inner signals to outter signals,
furthermore the => operator is used in switch-case structures and to map
single bits of a vector (0 => '1', 1 => '0', others => '0'), which means
bit 0 of the vector should be HIGH, bit 1 should be LOW and all other
bits should be LOW
