Forum: ARM programming with GCC/GNU tools Attribute aligned
von Thomas F. (thomas_f)
Hi ,
I am using ChanFat FS with code example from Martin Thomas.
1) There is an char array declared as
 BYTE Buff[16384] __attribute__ ((aligned (4))) ; /* Working buffer */.
Is there any reason to align this array to a divisible by 4 address ?
For example
char linebuf[120];      /* Console input buffer */
does not use the aligned attribute.
2)If someone can say whats the smallest ARM7/Cortex they have shoehorned
this FAT system it would help me.
Buff[16384] has been conservatively sized ?It does takes a lot of RAM.
Thomas
von Andreas S. (andreas) (Admin)
The array is probably accessed with a 32 bit pointer somewhere; on some
architectures (e.g., ARM) the array needs to be aligned to a 4 byte
boundary for that to work.
Thanks Andreas.
(1) as Andreas mentioned. On some devices the adress of the buffer is
used in the low-level drivers which may have restrictions i.e. on
DMA-adresses. On other targets the aligment might not be needed but can
do no harm (maybe even speeds things up a little bit)
(2) the buffer can be smaller the 16KiBytes are just used in the example
for benchmarking. If you look further down you will find the sice of the
buffer used for some copy-routines. See ChaN's API documentation to find
out which minimal buffer-sizes are needed.
