Forum: FPGA, VHDL & Verilog Problem Programming GAL22V10
Author: Zuga Bachocos (Company: ZUGA CORP) (zuga_bullzeye)
Hi! I'm trying to make a simple counter, from 0 to 99 using 8 bits. In
the GAL i have 2 inputs, one for the CLK and the other for the CLR. And
9 outputs, 4 for the units, 4 for the tens and 1 that just send '1' when
the counter has reached the limit. I'm using Galaxy for the code. The
code compiles well and i've also run a simulation and everything's fine.
The outputs are sent to a bar of leds, and 7 leds are on all the time,
nothing else happens. I'm using a G540 programmer.
Here is the code:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY CONTADOR IS
  PORT(CLK,CLR: IN STD_LOGIC;
     QUNI, QDEC: INOUT STD_LOGIC_VECTOR(3 DOWNTO 0);
     C: OUT STD_LOGIC
  ATTRIBUTE PIN_NUMBERS OF CONTADOR: ENTITY IS
  "CLK:1 CLR:2 C:23 "
&  "QDEC(3):22 QDEC(2):21 QDEC(1):20 QDEC(0):19 "
&  "QUNI(3):18 QUNI(2):17 QUNI(1):16 QUNI(0):15 ";
END CONTADOR;
ARCHITECTURE CUENTA OF CONTADOR IS
BEGIN
    PROCESS(CLK,CLR)
    BEGIN
        IF(CLR='1') THEN
         QUNI <= "0000";
       QDEC <= "0000";
       C <= '0';
      ELSIF(rising_edge(CLK)) THEN
          QUNI <= QUNI+1;
        C <= '0';
        IF(QUNI="1001") THEN
            QUNI <= "0000";
          QDEC <= QDEC+1;
          IF(QDEC="1010") THEN
             QUNI <= "0000";
           QDEC <= "0000";
           C <= '1';
          END IF;
        END IF;
    END IF;
    END PROCESS;
  END CUENTA;
HELP PLEASE!!!
> The code compiles well
Why do you use inout ports?
You just don't want to use local signals?
You find it a nice trick to use inout ports,
so you don't have to write that much code?
As far as I see these ports are NOT bidirectional!
This may cause problems.
I recommend to use local signals for the counters and a assignment to
the OUT ports for the LEDs.
Thats ok...
It it? So ... why do you have problems?
Additionally to the INOUT ports obviously the problem is generating the
correct programming file. Which GAL do you use?
Author: guest (Guest)
Zuga Bachocos wrotes:
The
So if the simulation succeeds you 've probably a bug in your hardware.
Please check your layout and conections.
Thanks!I've changed the INOUT. The problem, i think, its when
programming counters, because i tried to program other counter and it
doesn't work. I thought it was the programmer but i've programmed
succesfully a couple of 7-segment decoders and also a scanner for a
keypad.The first bit of the units should be on and off at the same
frcuency of the CLK, but with a led it stays on all the time but really
low, and the other bits of the units and the tens do he same. I'm using
GAL22V10.
> but with a led it stays on all the time but really low,
You mean: the pin is low, so the led is on?
>  at the same frcuency of the CLK
Whats the frequency?
Where does the CLK come from?
> The problem, i think, its when programming counters
So you're able to generate some combinatorial logic, but not things with
flipflops?
Try the simplest counter: a one bit toggling flipflop...
    PROCESS(CLK)
    BEGIN
      if rising_edge(CLK) then
         toggle <= not toggle;
      end if;
    END PROCESS;
    LED <= toggle;
Author: Uwe (Guest)
He have to read the Valu back here QDEC=QDEC+1. Ever when its on the
right side of the Equation ! It's a long time since i programmed GALs
but I think you have to define the MODE the GAL should have, so it can
make use of the Flip Flops and you dont have to build them on your own
with inout.
  • [vhdl]VHDL code[/vhdl]
