Forum: µC & Digital Electronics Lowpass + JK-FlipFlop
Author: naz (Guest)
Hello,
is anyone of you experienced at using a JK flip flop after a lowpass
filter?
(output signal of the lowpass filter connected to clock input of a JK
flip flop)
I have to filter a 1µs - pulse out of a signal that consists of 10ms -
pulses, and the filtered signal has to be applied to the clock input of
a JK flip flop. But as soon as a capacitor is connected at the clock
input, the flip flop isn't working anymore and is submitting a strange
output signal.
I tried several filter configurations (active and passive, first-,
second- and third-order) and three different flip flop ICs (74LS73,
74LS107, 74LS112), but nothing worked properly.
Are there additional conditions that I have to mind when using a JK flip
flop after a lowpass filter?
Thanks
Author: Uwe (Guest)
If you mix Analog and Digital Components you have to be sure not to use
the Digital parts in the Analog range. That means you have to use an
Shmitt-Trigger like the 7414 or a Comperator. But I think you should
explain what you want to do.
Author: naz (Guest)
I am using the JK flip flop as a frequency divider, and have to use a
lowpass filter to remove unwanted interference pulses, because the
voltage of this pulses is high enough to trigger the flip flop.
I tried to replace the JK flip flop with a D flip flop (74LS74), and it
seems like that this flip flop doesn't show the strange behaviour!
Author: Abdul K. (ehydra)
Some FFs have Schmitt-Trigger CLK input, e.g. 74HC74. They work after a
LP filter in a real circuit and in simulation - definitely!
With LS devices I see problems because the input is not so good
decoupled from the internal next stages as in CMOS.
Try to reduce the impedance of the LP filter. This may help to force and
hold the input voltage for the FF.
Ground bounce noise can be a problem with very fast logic on breadboard
or very poor routing.
Author: naz (Guest)
Thanks for your responses, I will use 74LS74, there are no problems with
this IC.
Next time use CMOS. It is much easier to handle. Have fun.
