Forum: ARM programming with GCC/GNU tools newlib behaviour no printf!
von Bangla B. (Company: Bangla) (bangla)
Hi All,
I am trying to use the printf (and all the IO functions of the stdlib)
unsuccessfully. My set-up is gcc 4.6.0 (patched), binutils 2.21
(patched) and newlib 1.19.0. I have a kernel, so the tools are created
to be reentrant. I have noticed that when I use printf, putc, etc. the
libc.a didn't call my routines (i.e _write_r, etc.). In the link I have
eliminated the reference to my syscall to verify that they were demanded
by the libc.a; It is the case. I have also noticed that libc.a call only
once one of my routine, the "void __malloc_lock(reent_t *reent)". Any
suggestion to fix this printf problem? Here is more information:
- cpu STM32
- stack lenght 8k
- Flags I used for building the newlib:
./configure --target=${TARGET} --prefix=${prefix} --enable-multilib \
  --enable-target-optspace --disable-nls   --enable-interwork \
  --enable-thumb --enable-newlib-multithread \
  --enable-newlib-io-long-long \
  --disable-libssp \
  --disable-libgloss \
  --disable-newlib-supplied-syscalls \
  --disable-newlib-atexit-alloc"
make -j 4 "CFLAGS=-Wno-error" \
          "CFLAGS_FOR_TARGET=-DREENTRANT_SYSCALLS_PROVIDED"
make install
make clean
I have also tried the Yagarto build with the same behavior.
Thank you for your help.
 Regards, Bangla
von Oliver (Guest)
Well, I don't know how to help you. The only thing I can say that I
successfully got it to work without big issues using Yagarto and newlib
1.19.0, although in the non-reentrant version.
Maybe you step through the code, to figure out where something goes
wrong, using either your Programmer or gdb in arm simulation mode.
Oliver
