Forum: ARM programming with GCC/GNU tools Help me check if there is a hang in this code due to infinite loop
von Yee Y. (Company: Infowave) (armgcc)
The loophere fn is definitely an infinite loop..
just want to verify concepts: if the condition is true for the all the
"if" case, will it end up in an infinite loop that causes a hang when
LEDB and LEDC are toggled? Loophere fn is outside the main loop whereas
the while(1) loop is inside the main loop.
int Main(void)
#endif
  if(ECFG_GetCentralAddress(&pGprsCenterAddr) != COM_SUCCESS)
    LoopHere();
         if (ECFG_GetUserAppConfig(&recEnable,
                              &recType,
                              &oneFixMaxIntervalSec,
                              &displacementThresholdMet,
                              &gprsMaxBytesPerSendToServer,
                              &gprsSendPeriodSec,
                              &pGprsRemoteIpAddr,
                              &gprsRemotePortNum)!= COM_SUCCESS){
        //ELOG_Printf0(LOG_CRITICAL, "GetUserAppConfig() failed!");
    LoopHere();
        if (EFLASH_Open(COM_SPI_PORT0, MCK/DATAFLASH_SPI_CLOCK_MHZ, 600,
                 1,
0,DATAFLASH_TOTAL_PAGES,DATAFLASH_TOTAL_BYTES_PER_PAGE,
          DATAFLASH_TOTAL_BITS_FOR_BYTE_FIELD_IN_COMMAND) !=
COM_SUCCESS)
        ELOG_Printf0(LOG_CRITICAL, "FLASH_Open failed!");
        while(1)
            ELED_Action(LEDB, LED_TOGGLE);
            ETIME_DelayMsec(50);
void LoopHere(void)
     while(1)
         ELED_Action(LEDC, LED_TOGGLE);
