Forum: µC & Digital Electronics Atmega1280: ADC-Interrupt-Vector is not called
von Ingo Heffe (Guest)
Hello,
during first experiments with an Atmega1280 (powered with 5V at 16Mhz) I
encountered one problem with the ADC-interrupt, although I followed the
specification :
The interrupt vector is not called although I enabled ADC functionality,
it's interrupt and the global interrupt, additionally I set the
ADSC-flag to
initiate the conversion, register settings:
DIDR0 = 0xFF ;    -> digital inputs disabled
DIDR2 = 0xFF ;    -> digital inputs disabled
ADCSRA = 0x8F;    -> ADEN, ADIE , prescaler 128, ADSC set at conversion
start
ADCSRB = 0 ;
ADMUX = 0 ;       -> AREF used
Did I miss any specification detail ?
It would be very helpful if someone could give me a hint what might be
the cause for this.
von Dadieter (Guest)
There is no "sei();"...only in your post or in your program too?
The sei() is in my main init function.
von Julian R. (tuefftler)
Please post your full code!
Is the ADC-Flag set? Can you use other intrrupts?
julian
von Hubert G. (hubertg)
You don´t start ADC.
ADCSRA = 0xCF;
A better script is:
ADCSRA = (1<<ADEN)|(1<<ADSC)|(1<<ADIE)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);
Finally the root cause could be identified as a RAM mapping problem
allocating the used application's RAM into the extended register
section.
This issue is solved now just by adding the following options to the
linker:
-Wl,-Map=$(TARGET).map -Wl,-Tdata,0x800200 -o $@ $(OBJS).
