Forum: Analog Circuits Active PFC in a 24V (Truck/Bus) network?
Author: Kayham (Guest)
Hello,
when I was seaching for infos on how to use a standard Computer
in a truck or bus, I came across the "active PFC" and read,
that I should use it in DC/DC converters to, to avoid the high
switching frequencies on the bordnet.
Can someone tell me, which PFC chip I should use for it and
maybe some links to application notes and schematics?
Thanks Kayham
Author: Martin (Guest)
I think that makes no sense. PFC means power factor correction, and for
a power factor you need alternating current. But in a 24V net, you have
DC current.
To reduce high switching currents, you just need a good filtering, so
input capacitors and inductors must be well chosen.
Regards,
Martin Antoni
This is one of the source where I found the thing with the DC PFC:
http://www.smps.us/power-supply.html
The PFC is AFTER the rectifier, hence on the DC side.
Can someone enlight me please?
Thanks
Author: Esko (Guest)
> and for  power factor you need alternating current.
He is right.
After the rectifier, you have also a alternating current, but only with
positive sign. And then, the current is drawn sinusodial, to match it
with the input voltage. This current is then stored in a 'big'
capacitor, which is in input to the next switching converter.
In this picture, you see the current, which matches in average a sinus
http://cr4.globalspec.com/PostImages/200911/PFC_cu...
Ah OK, makes sense.
Greetings Kayham
