Forum: ARM programming with GCC/GNU tools Hang - is there anything wrong with this code?
von Yee Y. (Company: Infowave) (armgcc)
Hi, I am using ublox 5 GPS and Atmel AT91SAM7S512.
basically, the microcontroller needs to perform GPRS vehicle tracking.
Not sure why. Everything runs fine but sometimes, the device just hangs
occasionally after some time.
When i compile eventhandler fn, for GPSBufferWrite(pPsvl,
sizeof(GPS_PSVL)), it returns me with a
"passing arg 1 of `GPSBufferWrite' from incompatible pointer type"
wonder if someone can help me look through these codes and see if there
is any problem.
The coding is compiling using embest IDE.
thanks a lot
ECOME_STATUS GPSBufferWrite(char *data, int size)
  //LOG2("GPSBufferWrite: data = %s, size = %d", data, size);
  //if (ReadGPSLogBufferPointer(&gpsPtr) == COM_SUCCESS)
    //LOG2("GPSBufferWrite: before, pWrite = %d, pRead = %d", gpsPtr.pWrite, gpsPtr.pRead);
      if ((gpsPtr.pWrite + size) <= MAX_GPS_BUFFER_SIZE)
      if (EFLASH_Write1(data, DATAFLASH_GPS_FIX_LOG_BUFFERING_DATA_ADDR + gpsPtr.pWrite, size) == COM_SUCCESS)
#if 0
        // read back verification
        char tmpbuf[200]="";
      EFLASH_Read(DATAFLASH_GPS_FIX_LOG_BUFFERING_DATA_ADDR + gpsPtr.pWrite, tmpbuf, size);
        if (strncmp(tmpbuf, data, size) != 0)
        LOG0("***** FLASHING ERROR *****");
 //tmpbuf[16] = 0x0;
 //LOG2("GPSBufferWrite: pwrite = %d, data = %s", gpsPtr.pWrite, tmpbuf);
#endif
 //LOG2("Before UpdatePointer, pWrite = %d, pRead = %d", gpsPtr.pWrite, gpsPtr.pRead);
        //data[16] = 0x0;
        LOG1("pwrite=%d", gpsPtr.pWrite);
#if 1
        gpsPtr.pWrite += size;
        UpdateGPSLogBufferPointer(&gpsPtr);
#endif
30
31
        return (COM_SUCCESS);
32
33
34
35
    else
36
37
  LOG1("GPSBufferWrite: (gpsPtr.pWrite + size) > MAX_GPS_BUFFER_SIZE, gpsPtr.pWrite = %d", gpsPtr.pWrite);
38
      //gpsPtr.pRead = 0;
39
      gpsPtr.pWrite = 0;
40
41
42
43
44
45
      //LOG0("Reset write pointer to 0");
46
47
48
49
50
51
52
53
static GPS_PSVL eventPsvl={0};
54
extern GPS_PSVL psvl;
55
56
57
void Events_Handler(unsigned int rtcStatus)
58
59
  extern char ringing;
60
  static char prevRinging = 0;
61
  unsigned char emergency3, tamper3, ignition3;
62
63
  static char flag_triggered = 0;
64
  static char xSampleCount = 0;
65
  static char ySampleCount = 0;
66
  static char zSampleCount = 0;
67
68
  static char adPowerValue[8];
69
  static char batteryValue[8];
70
  static char adSampCount = 0;
71
72
  float xdata,ydata,zdata;
73
  unsigned short currSpeed;
74
  GPS_PSVL *pPsvl;
75
  char msgLength;
76
  char xbuf[24];
77
  //char ybuf[24];
78
  //char zbuf[24];
79
  //char mbuf[24];
80
  ESYSS_CONFIG_EVENTS_SETUP1 *p = &sysEventsConfig1;
81
82
  //if (rtcStatus & RTC_SEC_CHANGE_BIT)
83
84
    memcpy(&eventPsvl,&psvl,sizeof(GPS_PSVL));
85
    pPsvl = &eventPsvl;
86
87
  //accelermeter
88
  if(sysEventsConfig1.enable & EVENT_ACCELERMETER)
89
90
    char xValue =0;
91
    char yValue = 0;
92
    char zValue = 0;
93
94
    if(flag_triggered)
95
96
    Accelerometor2(&xValue, &yValue, &zValue);
97
    xdata =255 * 0.66 * sysEventsConfig1.XLimited / 3.3;
98
    ydata =255 * 0.66 * sysEventsConfig1.YLimited / 3.3;
99
    zdata =255 * 0.66 * sysEventsConfig1.ZLimited / 3.3;
100
    //sprintf(xbuf,"%3.1f",xdata);
101
    //sprintf(ybuf,"%3.1f",ydata);
102
    //sprintf(zbuf,"%3.1f",zdata);
103
    //LOG3("xdata=%s,ydata=%s,zdata=%s",xbuf, ybuf, zbuf);
104
      if(xdata < xValue)
105
106
        flag_triggered = 1;
107
        xSampleCount++;
108
109
      if(ydata < yValue)
110
111
        flag_triggered = 1;
112
        ySampleCount++;
113
114
      if(zdata < zValue)
115
116
        flag_triggered = 1;
117
        zSampleCount++;
118
119
120
121
  }//accelermeter
122
123
  //every second
124
125
126
    //GPI
127
    emergency3 = (unsigned char)EIO_GetBit(0);
128
    //ETIME_DelayMsec(20);
129
130
131
    ignition3 = (unsigned char)EIO_GetBit(1);
132
133
134
135
    tamper3 = (unsigned char)EIO_TamperingCheck();
136
137
138
    //emergnecy cal
139
140
    if(preEmergency == 2)
141
      preEmergency = emergency3;
142
    else if(emergency3 != preEmergency )
143
144
      if(emergency3 == 1)
145
146
        if(sysEventsConfig1.enable & EVENT_EMERG_CALL)
147
148
          pPsvl->MsgType = EVENT_EMERG_CALL;
149
          pPsvl->MsgValue = 0;
150
          utc2LocalTime(pPsvl);
151
          GPSBufferWrite(pPsvl, sizeof(GPS_PSVL));
152
          FileLog(pPsvl);
153
154
155
156
157
158
    //tamper
159
    if(preTamper == 2)
160
      preTamper =  tamper3;
161
    else if(tamper3 != preTamper)
162
163
      if(tamper3 == 1)
164
165
        if(sysEventsConfig1.enable & EVENT_TAMPER)
166
167
          pPsvl->MsgType = EVENT_TAMPER;
168
169
170
171
          FileLog(pPsvl);
172
173
174
175
176
177
    //ignition
178
    if(preIgnition == 2)
179
      preIgnition = ignition3;
180
    else if(ignition3 != preIgnition)
181
182
      //LOG0("ignition pin level changed");
183
      if(sysEventsConfig1.enable & EVENT_IGNITION)
184
185
        LOG0("trigger ignition alert");
186
        pPsvl->MsgType = EVENT_IGNITION;
187
        pPsvl->MsgValue = ignition3;
188
189
190
        FileLog(pPsvl);
191
192
193
194
195
196
    //over speed and geofence
197
    if( pPsvl->flag_fix )
198
199
      //LOG0("gps fixed");
200
      if(sysEventsConfig1.enable & EVENT_OVER_SPEED)
201
202
        currSpeed = pPsvl->SOG;
203
        if(currSpeed > sysEventsConfig1.overspeed )
204
205
          pPsvl->MsgType = EVENT_OVER_SPEED;
206
207
208
209
          FileLog(pPsvl);
210
211
212
      //geo fence enter
213
      static char firstenter = 0;
214
      static char fistexit = 0;
215
      static char exitcounter = 0;
216
      if((sysEventsConfig1.enable & EVENT_ENTER_GEOZONE) || (sysEventsConfig1.enable & EVENT_EXIT_GEOZONE))
217
218
    unsigned int flag = sysGeofenceConfig1.EnableFlag;
219
    char count = sysGeofenceConfig1.NumberOfPoints;
220
        int i, temp = 0;
221
        float currDist = 0;
222
        for(i = 0; i < count; i++)
223
224
          temp = 1 << i;
225
          if(flag & temp)
226
227
            currDist = calcTwoPointsDistance(sysGeofenceConfig1.Point[i].Latitude,sysGeofenceConfig1.Point[i].Longitude,
228
                          pPsvl->Latitude, pPsvl->Longitude);
229
230
    //calcTwoPointsDistance(double preLat, double preLon, double Lat, double Lon)
231
             //sprintf(xbuf,"%.1f",currDist);
232
      //LOG1("distance = %s",xbuf);
233
234
235
236
    }//over speed and geofence
237
238
    static char firstmainlow  = 0;
239
    static char firstbattlow = 0;
240
    static short maincouter = 0;
241
    static short battcounter = 0;
242
    //analog: power lost or low
243
           if((sysEventsConfig1.enable & EVENT_POWER_LOW) || (sysEventsConfig1.enable &EVENT_POWER_LOST))
244
245
      adPowerValue[adSampCount] = EADC_Read(ADC_CH6);
246
      //ETIME_DelayMsec(1);
247
    batteryValue[adSampCount++] = EADC_Read(ADC_CH4);
248
      if(adSampCount >= 8)
249
250
        adSampCount = 0;
251
char averagePowerValue = (adPowerValue[0]+adPowerValue[1]+adPowerValue[2]+adPowerValue[3] +adPowerValue[4]+adPowerValue[5]+adPowerValue[7]+adPowerValue[8])/8;
252
253
  //double pi= 3.141592;
254
  //sprintf(xbuf,"%1.1f",sysEventsConfig1.mainPowerLow);
255
         //LOG1("%s",xbuf);
256
  float data = 255 * sysEventsConfig1.mainPowerLow * 0.2 / 3.3;
257
  //sprintf(xbuf,"%3.1f",data);
258
  //LOG2("data=%s,averagePowerValue=%d",xbuf,averagePowerValue);
259
        if(data >averagePowerValue)
260
261
      if(sysEventsConfig1.enable & EVENT_POWER_LOST)
262
263
          if(firstmainlow == 0){
264
  pPsvl->MsgType = EVENT_POWER_LOST;
265
266
267
268
  FileLog(pPsvl);
269
              firstmainlow = 1;
270
271
272
273
        else
274
          firstmainlow = 0;
275
        //sprintf(xbuf,"battery:%.1f",sysEventsConfig1.batteryLow);
276
        //LOG1("%s",xbuf);
277
        data =  255 * sysEventsConfig1.batteryLow * 0.5 / 3.3;
278
279
  //LOG2("data=%s,averageBattValue=%d",xbuf,averageBattValue);
280
  //LOG1("data=%d",data);
281
282
283
          if(sysEventsConfig1.enable & EVENT_POWER_LOW)
284
285
  if(firstbattlow == 0){
286
         pPsvl->MsgType = EVENT_POWER_LOW;
287
288
289
290
  FileLog(pPsvl);
291
              firstbattlow = 1;
292
293
294
295
296
297
    }//analog: power lost or low
298
299
    //incoming call
300
    if(sysEventsConfig1.enable & EVENT_INCOME_CALL)
301
302
      if ((prevRinging == 0) && (ringing == 1))
303
304
             prevRinging = ringing;
305
             pPsvl->MsgType = EVENT_INCOME_CALL;
306
307
308
309
             FileLog(pPsvl);
310
311
      else if ((prevRinging == 1) && (ringing == 0))
312
313
        prevRinging = 0;
314
315
316
317
    //GPS
318
    static int prevStatus = -1; // for GPS failure
319
    static EGPSE_ANTENNA_STATUS prevAntStatus = -1;
320
    int currStatus;
321
    EGPSE_ANTENNA_STATUS antStatus;
322
323
    currStatus = EGPS_GetStatus(&antStatus);
324
325
    if ((prevAntStatus == 1) && (antStatus == 2 ||antStatus == 3))
326
327
      //generate antenna alert
328
329
    prevAntStatus = antStatus;
330
331
    if ((prevStatus >= 0) && (currStatus < 0))
332
333
      //generate GPS fail alert
334
335
    prevStatus = currStatus;
336
337
  }//every second
338
339
von Jörg W. (dl8dtl) (Moderator)
Because obviously, the (unknown to us) definition of GPS_PSVL is most
likely not type "char", so taking a pointer to it is not compatible
with the char * argument your GPSBufferWrite is expecting.  Sounds
like you are a bit confused about which types to use for what ...
> is any problem.
Problems with "hanging" code usually relate to some kind of
(eventually) infinite loop.  The only loop in that piece of code
doesn't look like it could become an infinite one, so the problem is
very likely sitting elsewhere.  It should be easier to catch that
situation with some kind of online debugging by the time it happens
again, rather than from spotting it in the code itself.
yup... the code is not written by me...
i am trying to detect where the hang is...
i know the argument is not in char but dun understand why the data type
was put GPS_PSVL psvl
but i was thinking if incompatible pointer could lead to memory issues
such as stack overflow, leading to the hang...
problem is my boss don't wan to buy a debugger. no debugger to use.. so
i can only do trial and error...
can this be a possibility?
No, if the pointer were completely wrong, it would just never work.
von codehanger (Guest)
do you have a UART where you can put some debug output?
so put every code line/groupe a debugoutput i.e. "A", "B", ....
den run the system and log the output. so you can localize the code
section which cause the hang.
br
I see... so most likely, it is the while loop that causes problem?
thanks a lot...
Do have a serial port but the data is encrypted... !!! hyperterminal
can't read it... !!!
